Dead Boards
- jbeagle
Re: Dead Boards
I have not reported it anyplace but in this thread. It did not work on ether CircuitPython version. This is my third bad board. It would be nice if someone would test the boards before they are shipped.
- adafruit_support_carter
Re: Dead Boards
Just to be clear here - the screen behavior was as shown in the photos with both versions? That was the behavior out of the box?It did not work on ether CircuitPython version.
Also to make sure - the UF2 file you used to change to 7.3.3 was for the Titano? Downloaded from here?
https://circuitpython.org/board/pyportal_titano/
(and not accidentally a UF2 for one of the other PyPortals)
EDIT - Also, here's another useful test. It seems like you are able to get the Titano into bootloader mode OK, since you were able to upload a CircuitPython UF2. Get back into bootloader mode again, but this time drag over this self test UF2:
https://learn.adafruit.com/adafruit-pyp ... duino-test
The file named PyPortal_Titano_Self_Test.UF2. Can click on green button on that page to download. Any different behavior on the display with that?
- jbeagle
Re: Dead Boards
To be clear, The Titano Board came with CircuitPython 5.x on it and the screen was ghosted. I used a terminal window to run a " cp -X adafruit-circuitpython-pyportal_titano-en_US-7.3.3.uf2 /Volumes/PORTALBOOT " as the drag and drop does not work on the current version of Mac. The Titano board loaded the code just fine and the screen is still ghosted.
That is the behavior out of the box.
On to today ask, I put the Titano into boot loader mode and used the command to copy the new code over "cp -X PyPortal_Titano_Self_Test.UF2 /Volumes/PORTALBOOT" The screen is still ghosted and I have attached a pic of the screen. Please let me know the next step.
Re: Dead Boards
Thanks for the additional testing and info. For whatever reason, that's looking like a bad display. If think we've checked all the things that can be checked. All we can try is sending yet another Titano. We'd also like to RMA whatever non-working Titano boards you still have so we can look at them and try and figure out what is happening. The Titano stock was confirmed good before sending you that last board, so very mysterious what is happening here.
For the replacement, same process as before - send an email to [email protected] and link them to this thread and they can send you another Titano. Please also work with them to RMA whatever non-working Titano's you still have back.
Sorry this has been such an epic. Thanks for all the continued efforts in troubleshooting.
- jbeagle
Re: Dead Boards
thank you for working with me on this one. I have sent the email and I will return the bad board as soon as I get the RMA
- adafruit2
Re: Dead Boards
did the replacements work?
- jbeagle
Re: Dead Boards
Thank you for reaching out to me , yes the replacement board is working perfectly!
I hope everyone there had a great Christmas and hope you all have fun tonight!!
Happy new year to all!!
