HID not sending anything - TinyUSB
Knedl
Post by Knedl »
Hi, I am trying to send potentiometer value through HID to python, but I don't recieve anything, just blank. What could be wrong?
This is arduino code:
#include "Adafruit_TinyUSB.h"
#define REPORT_SIZE 16
uint8_t const desc_hid_report[] = {TUD_HID_REPORT_DESC_GENERIC_INOUT(REPORT_SIZE)};
Adafruit_USBD_HID usb_hid(desc_hid_report, sizeof(desc_hid_report), HID_ITF_PROTOCOL_NONE, 1, true);
char char_buf[REPORT_SIZE];
void setup()
pinMode(D8, INPUT_PULLDOWN);
#if defined(ARDUINO_ARCH_MBED) && defined(ARDUINO_ARCH_RP2040)
  TinyUSB_Device_Init(0);
#endif
  usb_hid.enableOutEndpoint(true);
  usb_hid.setPollInterval(1);
  usb_hid.setReportDescriptor(desc_hid_report, sizeof(desc_hid_report));
  usb_hid.setStringDescriptor("Spotify Keyboard");
  usb_hid.setReportCallback(get_report, NULL);
  usb_hid.begin();
  Serial.begin(115200);
  while( !TinyUSBDevice.mounted() ) delay(1);
  Serial.println("Adafruit TinyUSB HID Generic In Out example");
int sense(void){
int volume =analogRead(A0);
return volume;
uint16_t get_report(uint8_t report_id, hid_report_type_t report_type,
                    uint8_t *buffer, uint16_t reqlen)
  uint16_t size = snprintf(char_buf, REPORT_SIZE, "%d", sense());
  for (int i = 0; i < size; i++)
    buffer[i] = (uint8_t)char_buf[i];
  return size;
void loop()
This is pyton:
from re import S
import hid
import time
# default is TinyUSB (0xcafe), Adafruit (0x239a), RaspberryPi (0x2e8a), Espressif (0x303a) VID
USB_VID = (0xcafe, 0x239a, 0x2e8a, 0x303a)
print("VID list: " + ", ".join('%02x' % v for v in USB_VID))
for vid in  USB_VID:
    for dict in hid.enumerate(vid):
        print(dict)
        dev = hid.Device(dict['vendor_id'], dict['product_id'])
        if dev:
            while True:
                # Get input from console and encode to UTF8 for array of chars.
                # hid generic inout is single report therefore by HIDAPI requirement
                # it must be preceeded with 0x00 as dummy reportID
                # str_out = b'\x00'
                # str_out += input("Send text to HID Device : ").encode('utf-8')
                # dev.write(str_out)
                str_in = dev.read(0,16)
                print("Received from HID Device:", str_in, '\n')
                time.sleep(1)
adafruit_support_mike
Re: HID not sending anything - TinyUSB
As a sanity check, is your Python code even finding the TinyUSB device? For that matter, does it show up in the Device Manager when you connect the microcontroller to the computer?
Knedl
Post by Knedl »
Yes it finds it
What microcontroller are you using?
Knedl
Post by Knedl »
I am using Seeed XIAO RP2040
Return to “Arduino”
