Silicone Button PWM Controller
Wearable electronics: boards, conductive materials, and projects from Adafruit!
thinkdunson
Post by thinkdunson »
I'm just wondering if there's a datasheet for this product. On the Store, it says 3.6 ~ 12VDC. However, it's intended for automotive (motorcycle) implementation, so I would imagine it should be ok with the nominal running voltage of 13.5 ~ 14.5 VDC ???
Thanks for any help!
dastels
Re: Silicone Button PWM Controller
Post by dastels »
The description says:
These were originally designed for controlling heating pad modules in wearable thermal vests
So between 3.6v and 12v at 2A max. Those are the specs. Where do you read that it's intended for automotive/motorcycle use?
Return to “Wearables”
