the "getting started with adafruit circuit playground express" book, when we start installing circuit python libraries, on page 110 it says to copy them all onto the board and that it will take some time and should be around 400kb. the book is a bit old, and that same folder download for modern circuitpython is about 1.4mb~ now
is this still recommended?
Do I really need the whole lib folder? 1.4mb~
- bigguyjones
- Franklin97355
Re: Do I really need the whole lib folder? 1.4mb~
I don't know but I will ask the authors.
- adafruit_support_carter
This sounds specific to CircuitPython library usage? If so, then no - copying them all is not needed. In general, you only need the libraries to support whatever code usage you are running on the board. There may be several, and when the library folder was small, simply copying everything was the easiest approach. However, the total number of libraries has grown to where that approach generally won't work anymore - no board has enough space to hold *all* the libraries.
Here's the current guidance for working with CircuitPython libraries:
https://learn.adafruit.com/welcome-to-c ... -libraries
- bigguyjones
Yes thank you! I appreciate the help :)adafruit_support_carter wrote: ↑Sun Nov 20, 2022 11:16 am This sounds specific to CircuitPython library usage? If so, then no - copying them all is not needed. In general, you only need the libraries to support whatever code usage you are running on the board. There may be several, and when the library folder was small, simply copying everything was the easiest approach. However, the total number of libraries has grown to where that approach generally won't work anymore - no board has enough space to hold *all* the libraries.
