NeoKey 1x4 QT I2C Breakout not found
adam5532
Post by adam5532 »
I have a new NeoKey 1x4 QT I2C Breakout and it can not be found or reports the wrong address.
Bus scan Feather M4 w CP7.3.3:
Not found
Bus scan Feather ESP32-S3 CP8 beta4
0xb
The power light is on, and I know that the bus is good, as it is daisy-chained with STEMMA cables and a device connected after it is found and works properly.
I don't see any explanation other than that it is just defective, but checking if I missed anything.
adam5532
Re: NeoKey 1x4 QT I2C Breakout not found
Post by adam5532 »
Correction: 0xb is on the ESP32-S3 Feather, so it isn't being found on that micro either.
adafruit_support_carter
Which specific Feather M4 are you using?
adam5532
Post by adam5532 »
M4 Express 3857
and
ESP32-S3 Feather with 4MB Flash 2MB PSRAM 5477
Thanks. For now, focusing on just the Feather M4. The Feather M4 Express (PID 3857) does not have a dedicated STEMMA QT connector, so the header pins will need to be used - at least on the Feather side. How are you making the connection between the Feather M4 and the NeoKey?
adam5532
Post by adam5532 »
Breadboard pins to STEMMA connector. The encoder is daisychained after the NeoKey to verify that power and I2C bus connections are good. Only the decoder at 0x36 is found.
Thanks for the photo of the setup and test output.
Just to check - are the headers soldered on the Feather?
adam5532
Post by adam5532 »
Yes, of course they are soldered. Same result plugging into breadboard vs directly into M4 headers.
OK, thanks for verifying. That all seems fine. Not sure what's wrong - the address should just show up like the rotary knob. Let's just replace it.
Send an email to [email protected] with a link to this thread and your order number and they can send you a replacement NeoKey 1x4.
adam5532
Post by adam5532 »
OK, thanks.
