Can I calibrate the Aht20 sensor?
Broekieman
Post by Broekieman »
I bought the Aht20 breakout board and the temperature is 1 degree lower than my other sensor. Can I calibrate this sensor and how? I am using it in Home assistant with esphome.
Franklin97355
Re: Can I calibrate the Aht20 sensor?
Post by Franklin97355 »
There is no hardware calibration available but you could add 1 to your reading to compensate. There are documents here
mikeysklar
Post by mikeysklar »
The sensor can self calibrate and will return true on success.
This is something you can do with CircuitPython or the Arduino library. There is a bit to enable self calibrate and another to read the result.
https://docs.circuitpython.org/projects ... t/api.html
#define AHTX0_CMD_CALIBRATE 0xE1     ///< Calibration command
#define AHTX0_STATUS_CALIBRATED 0x08 ///< Status bit for calibrated
https://github.com/adafruit/Adafruit_AH ... it_AHTX0.h
Broekieman
mikeysklar wrote: Mon Nov 21, 2022 4:49 pm The sensor can self calibrate and will return true on success.
I am new to this. Do i need a special board to use arduino and what is the complete code for arduino to calibrate the sensor? Or can calibration only be done with Circuit Python and a special board?
mikeysklar
We don't have example code for doing the calibrate, but I can probably save you some effort here.
The AHT20 is +/- .3C accuracy. Which means you will typically see a 1 degree Fahrenheit skew between devices.
This sensor has a typical accuracy of +- 2% relative humidity, and +-0.3 °C at 20-80% RH and 20-60 °C. There is only one I2C address so it's not a good option when you need multiple humidity sensors.
https://www.adafruit.com/product/4566
Broekieman
It is +-0.3 °C and I have +- 1. °C
Broekieman
What board do you advice for CircuitPython? Can someone explain how sellf calibrating works?
