Pyportal Titano crashing in adafruit_requests
HowdyMoto
Post by HowdyMoto »
I'm running this Google Calendar app, provided by Adafruit:
https://github.com/adafruit/Adafruit_Le ... ar/code.py
When I let my Pyportal Titano run, it always ends up crashing after some unpredictable amount of time in adafruit_requests. This line (line 124)
resp = pyportal.network.requests.get(url, headers=headers)
Crashes occasionally with this error in adafruit_requests, and is a little bit over my head:
  File "code.py", line 244, in <module>
  File "code.py", line 77, in get_current_time
  File "adafruit_portalbase/__init__.py", line 488, in get_local_time
  File "adafruit_portalbase/network.py", line 240, in get_local_time
  File "adafruit_portalbase/network.py", line 209, in get_strftime
  File "adafruit_requests.py", line 820, in get
  File "adafruit_requests.py", line 666, in request
  File "adafruit_requests.py", line 518, in _get_socket
RuntimeError: Sending request failed
Sometimes it'll go ten minutes. Sometimes it'll go for hours before crashing.
I'm running CircuitPython 8 Beta 4, with all the very latest libs, but I've had this problem on every version dating back at least a year.
Seems to me like this is a bug or uncaught error in the adafruit_requests library, right? Or is there something I could do here to fix this in my calendar app?
mikeysklar
Re: Pyportal Titano crashing in adafruit_requests
Post by mikeysklar »
You will need to upload the latest nina-fw to the ESP32 on your PyPortal Titano. There was a problem with old firmware handling https certificates over more than 1300 bytes which has been resolved.
guide to update firmware:
https://learn.adafruit.com/upgrading-es ... t-firmware
github issue:
https://github.com/adafruit/Adafruit_Ci ... issues/101
HowdyMoto
Post by HowdyMoto »
Hi Mikey, unfortunately, that doesn't fix the issue. It still happens even after updating the Nina firmware.
Any other ideas?
I've been wanting to sell some of the PyPortal devices I've put together with nice, handmade cases, but sadly the Titano has been too unstable.
mikeysklar
Thank you for trying the NINA FW update.
Looking at the original crash message you started with I see the trace being initiated by get_local_time.
Can you post the exact code you are running as the line numbers don't align with the example google calendar code. Obviously comment out any personal information, but keep the line numbers the same.
The thing to try is to wrap queries with try/except like this example:
        try:
            print("Getting new time from internet...")
            pyportal.get_local_time(secrets['timezone'])
            refresh_time = time.monotonic()
            # set the_time
            the_time = time.localtime()
        except (ValueError, RuntimeError, ConnectionError, OSError) as e:
            print("Failed to get data, retrying\n", e)
            esp.reset()
            continue
HowdyMoto
Post by HowdyMoto »
Thanks for all your help so far!
I got a fresh version of this code from GitHub to make sure this isn't my fault. Here's the code:
# SPDX-FileCopyrightText: 2021 Brent Rubell, written for Adafruit Industries
# SPDX-License-Identifier: Unlicense
import time
from adafruit_oauth2 import OAuth2
from adafruit_display_shapes.line import Line
from adafruit_pyportal import PyPortal
import rtc
# Calendar ID
CALENDAR_ID = "[email protected]"
# Maximum amount of events to display
MAX_EVENTS = 5
# Amount of time to wait between refreshing the calendar, in minutes
REFRESH_TIME = 15
MONTHS = {
    1: "Jan",
    2: "Feb",
    3: "Mar",
    4: "Apr",
    5: "May",
    6: "Jun",
    7: "Jul",
    8: "Aug",
    9: "Sep",
    10: "Oct",
    11: "Nov",
    12: "Dec",
# Dict. of day names for pretty-printing the header
WEEKDAYS = {
    0: "Monday",
    1: "Tuesday",
    2: "Wednesday",
    3: "Thursday",
    4: "Friday",
    5: "Saturday",
    6: "Sunday",
# Add a secrets.py to your filesystem that has a dictionary called secrets with "ssid" and
# "password" keys with your WiFi credentials. DO NOT share that file or commit it into Git or other
# source control.
# pylint: disable=no-name-in-module,wrong-import-order
try:
    from secrets import secrets
except ImportError:
    print("WiFi secrets are kept in secrets.py, please add them there!")
    raise
# Create the PyPortal object
pyportal = PyPortal()
r = rtc.RTC()
pyportal.network.connect()
# Initialize an OAuth2 object with GCal API scope
scopes = ["https://www.googleapis.com/auth/calendar.readonly"]
google_auth = OAuth2(
    pyportal.network.requests,
    secrets["google_client_id"],
    secrets["google_client_secret"],
    scopes,
    secrets["google_access_token"],
    secrets["google_refresh_token"],
def get_current_time(time_max=False):
    """Gets local time from Adafruit IO and converts to RFC3339 timestamp."""
    # Get local time from Adafruit IO
    pyportal.get_local_time(secrets["timezone"])
    # Format as RFC339 timestamp
    cur_time = r.datetime
    if time_max:  # maximum time to fetch events is midnight (4:59:59UTC)
        cur_time_max = time.struct_time(
                cur_time[0],
                cur_time[1],
                cur_time[2] + 1,
                4,
                59,
                59,
                cur_time[6],
                cur_time[7],
                cur_time[8],
        cur_time = cur_time_max
    cur_time = "{:04d}-{:02d}-{:02d}T{:02d}:{:02d}:{:02d}{:s}".format(
        cur_time[0],
        cur_time[1],
        cur_time[2],
        cur_time[3],
        cur_time[4],
        cur_time[5],
        "Z",
    return cur_time
def get_calendar_events(calendar_id, max_events, time_min):
    """Returns events on a specified calendar.
    Response is a list of events ordered by their start date/time in ascending order.
    time_max = get_current_time(time_max=True)
    print("Fetching calendar events from {0} to {1}".format(time_min, time_max))
    headers = {
        "Authorization": "Bearer " + google_auth.access_token,
        "Accept": "application/json",
        "Content-Length": "0",
    url = (
        "https://www.googleapis.com/calendar/v3/calendars/{0}"
        "/events?maxResults={1}&timeMin={2}&timeMax={3}&orderBy=startTime"
        "&singleEvents=true".format(calendar_id, max_events, time_min, time_max)
    resp_json = resp.json()
    if "error" in resp_json:
        raise RuntimeError("Error:", resp_json)
    resp.close()
    # parse the 'items' array so we can iterate over it easier
    items = []
    resp_items = resp_json["items"]
    if not resp_items:
        print("No events scheduled for today!")
    for event in range(0, len(resp_items)):
        items.append(resp_items[event])
    return items
def format_datetime(datetime, pretty_date=False):
    """Formats ISO-formatted datetime returned by Google Calendar API into
    a struct_time.
    :param str datetime: Datetime string returned by Google Calendar API
    :return: struct_time
    times = datetime.split("T")
    the_date = times[0]
    the_time = times[1]
    year, month, mday = [int(x) for x in the_date.split("-")]
    the_time = the_time.split("-")[0]
    if "Z" in the_time:
        the_time = the_time.split("Z")[0]
    hours, minutes, _ = [int(x) for x in the_time.split(":")]
    am_pm = "am"
    if hours >= 12:
        am_pm = "pm"
        # convert to 12hr time
        hours -= 12
    # via https://github.com/micropython/micropython/issues/3087
    formatted_time = "{:01d}:{:02d}{:s}".format(hours, minutes, am_pm)
    if pretty_date:  # return a nice date for header label
        formatted_date = "{} {}.{:02d}, {:04d} ".format(
            WEEKDAYS[r.datetime[6]], MONTHS[month], mday, year
        return formatted_date
    # Event occurs today, return the time only
    return formatted_time
def create_event_labels():
    for event_idx in range(MAX_EVENTS):
        event_start_label = pyportal.add_text(
            text_font=font_events,
            text_position=(7, 70 + (event_idx * 40)),
            text_color=0x000000,
        event_text_label = pyportal.add_text(
            text_position=(88, 70 + (event_idx * 40)),
            line_spacing=0.75,
        event_labels.append((event_start_label, event_text_label))
def display_calendar_events(resp_events):
    # Display all calendar events
    for event_idx in range(len(resp_events)):
        event = resp_events[event_idx]
        # wrap event name around second line if necessary
        event_name = PyPortal.wrap_nicely(event["summary"], 25)
        event_name = "\n".join(event_name[0:2])  # only wrap 2 lines, truncate third..
        event_start = event["start"]["dateTime"]
        print("-" * 40)
        print("Event Description: ", event_name)
        print("Event Time:", format_datetime(event_start))
        print("-" * 40)
        pyportal.set_text(format_datetime(event_start), event_labels[event_idx][0])
        pyportal.set_text(event_name, event_labels[event_idx][1])
    # Clear any unused labels
    for event_idx in range(len(resp_events), MAX_EVENTS):
        pyportal.set_text("", event_labels[event_idx][0])
        pyportal.set_text("", event_labels[event_idx][1])
pyportal.set_background(0xFFFFFF)
# Set up calendar event fonts
font_events = "fonts/Arial-14.pcf"
# Add the header
line_header = Line(0, 50, 320, 50, color=0x000000)
pyportal.splash.append(line_header)
label_header = pyportal.add_text(
    text_font="fonts/Arial-18.pcf",
    text_position=(10, 30),
event_labels = []
if not google_auth.refresh_access_token():
    raise RuntimeError("Unable to refresh access token - has the token been revoked?")
access_token_obtained = int(time.monotonic())
events = []
while True:
    # check if we need to refresh token
    if (
        int(time.monotonic()) - access_token_obtained
        >= google_auth.access_token_expiration
        print("Access token expired, refreshing...")
            raise RuntimeError(
    # fetch calendar events!
    print("fetching local time...")
    now = get_current_time()
    # setup header label
    pyportal.set_text(format_datetime(now, pretty_date=True), label_header)
    print("fetching calendar events...")
    events = get_calendar_events(CALENDAR_ID, MAX_EVENTS, now)
    print("displaying events")
    display_calendar_events(events)
    print("Sleeping for %d minutes" % REFRESH_TIME)
    time.sleep(REFRESH_TIME)
I ran it for a few hours tonight and it crashed on line 124 in get_calendar_events, which also calls adaferuit_requests.py, line 518, in _get_socket
I'll try the try/except addition you mention below as well, thanks!
HowdyMoto
Post by HowdyMoto »
Hi Mikey,
Seems like PyPortal initiates the esp32 chip, making it inaccessible unless I rewrite the app using lower-level libraries. That's doable, but unfortunate. I'll file a ticket to add a reset function to PyPortal or portalbase
PS - I also frequently get SPI-related crashes, and a reset function might be useful there, too.
Cheers,
Wright
