PyPortal status LED not displaying expected color
macewmi
Post by macewmi »
According to https://learn.adafruit.com/welcome-to-c ... 2978455-24, the status pixel on a PyPortal displays the following colors.
What does the status NeoPixel indicate once my code.py is
running?
Once your PyPortal boots up and successfully loads your code.py or
main.py, the status NeoPixel will turn green briefly. Then, the
NeoPixel will show one of the following color codes to indicate the
status of the WiFi connection/activity or file operations:
Red = not connected to WiFi
Blue = connected to WiFi
Yellow = fetching data
Blue = got data
Cyan = file opening
But both the Countdown Timer https://learn.adafruit.com/pyportal-eve ... down-clock and Hurricane Tracker https://learn.adafruit.com/pyportal-hurricane-tracker example apps don't exhibit that behavior.
Countdown Timer goes to RED and stays there the entire time.
Hurricane Tracker goes RED, changes to YELLOW and stays there.
To test the status LED, I ran this code:
import time
import board
import neopixel
pixels=neopixel.NeoPixel(board.NEOPIXEL, 1)
    pixels.fill((0, 0, 255))
whileTrue:
    pass
And the status LED turned BLUE suggesting that it's not a hardware problem.
Can anyone explain why those example apps don't work as expected?
TIA
adafruit_support_carter
Re: PyPortal status LED not displaying expected color
What version of CircuitPython are you running? Can check by looking in the boot_out.txt file located in the CICUITPY folder.
macewmi
Post by macewmi »
I’m away right now, so without actually looking at the file, I want to say 7.3.3(?)
OK, I'm seeing same general behavior on a PyPortal running the Hurricane tracker. Code seems to run fine. But NeoPixel is not changing color exactly as described - or at least doesn't appear to be.
I've pinged the library author to take a look. Maybe something has changed and that info needs updating.
Just to check - is everything running OK for your setup? It's just the behavior of the NeoPixel that's in question?
macewmi
Post by macewmi »
Everything is running fine except for the status LED. Thanks.
macewmi
Post by macewmi »
Ran some additional tests. Very interesting results. Here's the code.
import time
import board
from adafruit_pyportal import PyPortal
cwd = ("/"+__file__).rsplit('/', 1)[0]
pyportal = PyPortal(status_neopixel=board.NEOPIXEL,
                    default_bg=cwd+"/countdown_background.bmp")
print("Get time 1")
try:
    print("Getting time from internet!")
    pyportal.get_local_time()
except RuntimeError as e:
    print("Some error occured, retrying! -", e)
    continue
print("Time 1 got")
print("Get time 2")
try:
    continue
print("Time 2 got")
time.sleep(10)
while True:
	pass
RESULTS:
The status_led flashes GREEN at power-up and goes dark. Expected.
The status goes RED right after "Get Time 1". Expected.
It stays RED after "Time 1 got". BLUE is expected.
Immediately after "Get Time 2", it goes BLUE!! And stays BLUE
MakerMelissa
Post by MakerMelissa »
Thanks, I just grabbed my PyPortal and reproduced the same results you had. I'm going to dig in and see why the lights are different. Most likely the library just needs a few tweaks.
MakerMelissa
Here's the colors currently in the library:
STATUS_NO_CONNECTION = (100, 0, 0)  # Red
STATUS_CONNECTING = (0, 0, 100)     # Blue
STATUS_FETCHING = (200, 100, 0)     # Orange
STATUS_DOWNLOADING = (0, 100, 100)  # Cyan
STATUS_CONNECTED = (0, 100, 0)      # Green
STATUS_DATA_RECEIVED = (0, 0, 100)  # Blue
STATUS_OFF = (0, 0, 0)              # Off
It looks like they're slightly different than the documentation with Green meaning connected and Blue meaning in the process of connecting or Data Received. Fetching should probably be changed to yellow instead of orange.
MakerMelissa
I created an issue in GitHub with the issues I saw regarding the mismatch: https://github.com/adafruit/Adafruit_Ci ... /issues/83
MakerMelissa
I submitted a fix. Please note that once the fix is merged in, the frozen library inside the firmware will still need to be updated as well and it would only update on future firmware releases.
macewmi
Post by macewmi »
Thank you for fixing that.
What will I be keeping an eye out for to ensure I get the fix downloaded? Am I watching for an updated UF2 file? new library bundle?
MakerMelissa
Thanks for the reminder. I need to update my CircuitPython repo, run a script to update frozen libraries and submit a PR. Then it would be in the next release after that's merged in.
For now, you can always download the updated library and stick it in the root (top level) folder of your device, which is how I tested it. Since it's a frozen library, the built-in one will override anything in the lib folder, but not from the root.
Melissa
MakerMelissa
I submitted a PR here if you'd like to watch it: https://github.com/adafruit/circuitpython/pull/7248
MakerMelissa
Ok, apparently updating the libraries is a normal part of the release process, so it should automatically be part of the next CircuitPython 8 Beta release at least.
macewmi
Post by macewmi »
OK. Thanks. I'll keep an eye out for that.
