Multiple touch input cap1188
ninanas98
Post by ninanas98 »
I am using cap1188 to detect the water level in a kettle. I got to the point where the water level was seen in the sense that the leads on the board lit up. Now I want to code it so that if the water level is detected by C1 and C2 that a display shows "2". if the water level is at C3 (also touching C1 & C2) it says "3" and so on.
I tried using an if statement combining the different inputs with "&&" but this doesn't seem to work (see below). How can I fix this issue? It worked fine when I used 2 boards and used this type of coding between the 2 boards.
Thank you in advance!
#include <Arduino.h>
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_CAP1188.h>
#include <TM1637Display.h>
// Module connection pins (Digital Pins)
#define CLK 4
#define DIO 5
TM1637Display display(CLK, DIO);
// Use I2C, no reset pin!
Adafruit_CAP1188 cap = Adafruit_CAP1188();
  if (!cap.begin()) {
    //Serial.println("CAP1188 not found");
    while (1);
  Serial.println("CAP1188 found!");
  display.setBrightness(0x0f);
  uint8_t touched = cap.touched();
  for (uint8_t i = 0; i < 8; i++) {
    if (touched & (1 << i)) {
      Serial.print("C"); Serial.print(i + 1); Serial.print("\t");
  if (touched & 0x01) {
    display.showNumberDec(1, false);
    delay(50);
  else if ((touched & 0x01) && (touched & 0x02)) {
    display.showNumberDec(2, false);
    delay(50);
  else  if ((touched & 0x01) && (touched & 0x02) && (touched & 0x04)) {
    display.showNumberDec(3, false);
    delay(50);
  else  if ((touched & 0x01) && (touched & 0x02) &&(touched & 0x04) && (touched & 0x08)) {
    display.showNumberDec(4, false);
    delay(50);
  else  if ((touched & 0x01) && (touched & 0x02) &&(touched & 0x04) &&(touched & 0x08) && (touched & 0x10)) {
    display.showNumberDec(5, false);
    delay(50);
  else  if ((touched & 0x01) && (touched & 0x02) &&(touched & 0x04) &&(touched & 0x08) &&(touched & 0x10) && (touched & 0x20)) {
    display.showNumberDec(6, false);
    delay(50);
  else if ((touched & 0x01) && (touched & 0x02) &&(touched & 0x04) &&(touched & 0x08) &&(touched & 0x10) &&(touched & 0x20) && (touched & 0x40)) {
    display.showNumberDec(7, false);
    delay(50);
  else
dastels
Re: Multiple touch input cap1188
Post by dastels »
You need to flip your if ladder over and get rid of the "&&"s because it will now stop at the highest level it finds. I'd also extract the delay since they are all the same and because having duplicate code like that is error prone. You had 7 lines to change if you wanted to change the delay rather than 1. This part is optional.
  if (touched & 0x40) {
  } else if (touched & 0x20) {
  } else if (touched & 0x10) {
  } else if (touched & 0x08) {
  } else if (touched & 0x04) {
  } else if (touched & 0x02) {
  } else if (touched & 0x01) {
  if (touched & 0x7F) {   // any of them triggered
    delay(50);
ninanas98
Post by ninanas98 »
Thanks Dave!!!
