I am testing the Adafruit 'adafruitio_15_temp_humidity' sketch but cannot login. This is the error I get:
My IO credentials are correct and have been used for over a year on another sketch.
My wifi credentials are also correct and well tested.
I followed the info about updating my SSL certificates on this webpage:
https://learn.adafruit.com/adafruit-fea ... rtificates
As can be seen the Talavera domain has been uploaded.
I found some good help on this Adafruit webpage
https://learn.adafruit.com/welcome-to-a ... io-project
which has specific info the the Feather MO WIFI which I am using. I did all of that and I still not able to connect.
Any help will be greatly appreciated.
Thanks.
Cannot Login To IO
- jwcooper
Re: Cannot Login To IO
Any errors on https://io.adafruit.com/monitor while you try to connect?
- _phillip
Thanks so much for your post.
To back up a bit, because I am using an Adafruit Feather MO WIFI the norm has always been to set the wifi pins for this board. The 'adafruitio ...' sketch that I am testing oddly does not mention setting these wifi pins anywhere. Because of that, I thought this was what was preventing the sketch from connecting to the Adafruit IO so I added that code to the sketch. That was no help which makes me wonder why this code is recommended for Feather boards to make a wifi connection but seems not to matter in this particular sketch?
At any rate, I did as you suggested. Here is a grab of what I saw. I will re-install all credentials and try again.
Thank you.
Thank you.
- brubell
- Learn User Page
Hi - jumping in. Do the other sketches (like adafruitio 1) which involve setting the WiFi pins work for you? Is it just this sketch?To back up a bit, because I am using an Adafruit Feather MO WIFI the norm has always been to set the wifi pins for this board. The 'adafruitio ...' sketch that I am testing oddly does not mention setting these wifi pins anywhere. Because of that, I thought this was what was preventing the sketch from connecting to the Adafruit IO so I added that code to the sketch.
- _phillip
I should have mentioned that I do not have the DHT22 wired up to this Feather that I am using for this sketch. I am simply trying to learn how this particular code makes a wifi connection to IO.
I will wire up the DHT22 to this board and see if that is affecting my wifi connect issue.
Thank you.
Thank you.
- _phillip
@brubell
Background
The test Feather MO WIFI board had its Firmware updated as well as having its SSL certificate reinstalled yesterday as seen next:
I uploaded my test sketch to another Feather MO WIFI board and the test sketch worked as it always has. So, somehow, the 'updating' that I did yesterday to the test Feather board has prevented it from working as it always had.
In addition, I am still plagued with the 'overload' error message. It is very random and exists with both Arduino IDE's. I overcome it by opening/closing the sketch until it stops. I know you probably do not believe this, but this is the way it is. It makes no sense to me.
I appreciate your help. Thank you.
Every sketch that I have coded up using a Feather MO WIFI board has had the WIFI pins set as noted above. However, my tried-and-true test sketch compiled without error this morning, but did not send texts as it always had using my test Feather MO WIFI board.
Background
- _phillip
It seems that the IO has changed because my Dashboards are no longer visible. This is what I saw while logged in using my water project Feather board as shown next.
To be clear - this is not data from the 'adafruitio...' sketch. This data came from my water project Feather board as shown next.
The 'adafruitio...' sketch still will not login. Thanks.- jwcooper
What is the rate you are sending data to IO?
I'm not entirely sure what's going on yet with the disconnections, sending too much data too quickly would cause a disconnection, I think.
