PY RP-2040 I followed the instructions on this page https://learn.adafruit.com/adafruit-qt-py-2040/blink-2
I do see the RPI-RP2 automount
Arduino IDE V 1.8 with mbed libraries loaded
It appears this is a common problem, but I can find anything that will make it work.
I'm open to suggestions.
fail to upload sketch
- mikeysklar
Re: fail to upload sketch
From the Arduino IDE when you go to upload what error do you see?
Make sure that Verbose output is enabled for compilation / upload. The check boxes to enable it are under File --> Preferences.
Also which specific 1.8.x version are you running?
- Claude_J_Greengrass
Here is the error message (verbose)
Sketch uses 49788 bytes (2%) of program storage space. Maximum is 2093056 bytes.
Global variables use 7316 bytes (2%) of dynamic memory, leaving 254828 bytes for local variables. Maximum is 262144 bytes.
/home/jlk/.arduino15/packages/rp2040/tools/pqt-python3/1.0.1-base-3a57aed/python3 -I /home/jlk/.arduino15/packages/rp2040/hardware/rp2040/2.6.3/tools/uf2conv.py --serial /dev/ttyACM0 --family RP2040 --deploy /tmp/arduino_build_681747/Blink.ino.uf2
Resetting /dev/ttyACM0
An error occurred while uploading the sketch
Converting to uf2, output size: 130048, start address: 0x2000
No drive to deploy.
I am running Arduino IDE version 1.8.19 under Ubuntu (64 bit)
The drive RPI-RP2 was automounted
There are 2 files on this drive: INDEX.HTM and INFO_UF2.TXT
No drive to deploy.
To eliminate possible errors caused by modified hardware, I ordered a fresh QT PY RP2040 and the Adafruit USB cable. When I plug it in, the led 'fades' through a rainbow of colours. This suggests to me that the fade.ino sketch was loaded before it was shipped to me. No problems there.
Now when I try to compile and download the fade sketch I get the error:
/home/jlk/.arduino15/packages/rp2040/tools/pqt-openocd/1.4.0-c-0196c06/bin/openocd: error while loading shared libraries: libhidapi-hidraw.so.0: cannot open shared object file: No such file or directory
And yes, libhidap-hidraw.so.0 is missing. Hints as to how to solve this would be greatly appreciated.
- mikeysklar
I'm surprised it would look for an openocd library. Can you show the drop down of your Arduino IDE --> Tools menu. This error sounds like you have a jtag programmer selected.
thanks for the reply mikeysklar
I updated ubuntu and have fixed the above problem with apt-get.
I can see a "disk" RPI-RP2 and I tried to copy fade.ino.elf.uf2 to that device with no success
I still cannot see a Port from the Tools menu of the IDE and I get the following error when I attempt to download a compiled file:
Open On-Chip Debugger 0.10.0+dev-ge3428fadb-dirty (2022-07-14-14:57)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
Info : Hardware thread awareness created
Info : RP2040 Flash Bank Command
Error: unable to find CMSIS-DAP device
Error: No Valid JTAG Interface Configured.
- mikeysklar
Just to confirm you have installed the Earle Philhower Core from the Boards Manager (in the Arduino IDE)?
https://learn.adafruit.com/adafruit-qt- ... rl-3107182
Don't worry about the port not being available. The RP2040 does not need that for the Arduino IDE.
I am concerned that one of your Arduino IDE Tools setting is set to JTAG. You are not using a JTAG programmer so that is the source of the IDE not working correctly to upload. Your screen needs to resemble the guide screenshot:
Good thought trying to manually copy the UF2 did you drop it through the graphical 'Files' program under Ubuntu? That has worked for me on my Ubuntu laptop.
https://learn.adafruit.com/adafruit-qt- ... rd-3107193If there is no serial Port available in the dropdown, or an invalid one appears - don't worry about it! The RP2040 does not actually use a serial port to upload, so its OK if it does not appear if in manual bootload mode. You will see a serial port appear after uploading your first sketch
