I'm a programmer by trade, and an all-thumbs beginner when it comes to anything hardware-wise. I'm planning to build the LED Protest Sign. I've opted for the larger sign which apparently requires the Feather M4 Express and the FeatherWing. I have all the Adafruit parts listed in the guide except for the currently out-of-stock 5.5 / 2.1mm Barrel Connector - DC Power Plug, and...
...the Adafruit Feather M4 Express - Featuring ATSAMD51 - ATSAMD51 Cortex M4 which appears to be perpetually / permanently out-of-stock, and I have no idea if there's a compatible equivalent that can be attached and programmed using the instructions in the guide. (I don't know enough to improvise.)
I was hoping to get this done in time for a December 15th protest. So, is there an alternative or is there hope that the part will come in?
Thanx!
Substitution for Feather M4 ExpressATSAMD51 Cortex M4?
- ubuntourist
- dastels
Re: Substitution for Feather M4 ExpressATSAMD51 Cortex M4?
You could switch to a MatrixPortal https://www.adafruit.com/product/4745 Which is essentially a Feather M4 Express, a Matrix Featherwing, and an Airlift Featherwing all on one board. And it's in stock.
- dastels
Another option is the Feather RP2040 https://www.adafruit.com/product/4884 but it's also out of stock.
- ubuntourist
I've already purchased the larger display, with the thought that the M4 Express was only temporarily out of stock. I may go with the MatrixPortal if I don't find another solution, but since I've already got the larger display I was thinking that perhaps the reason the M4 Express wasn't available was because it was superseded by something newer that would get the job done.dastels wrote: ↑Fri Nov 25, 2022 10:44 pm You could switch to a MatrixPortal https://www.adafruit.com/product/4745 Which is essentially a Feather M4 Express, a Matrix Featherwing, and an Airlift Featherwing all on one board. And it's in stock.
- dastels
The M4 Express is still a going concern. The problem is with the chip supply chain.
