Here is something new.
Now the code uploaded successfully on my RP2030 (no error message) and my screen is blue!
I get this message on my Serial monitor:
Adafruit SPIFlash Animated GIF Example
Flash chip JEDEC ID: 0xC84017
Mounted filesystem!
86526 2022-11-21 16:10 badger-172.gif
0 2020-01-01 00:00 .Trashes
22 2020-01-01 00:00 code.py
0 2020-01-01 00:00 lib/
115 2020-01-01 00:00 boot_out.txt
4096 2022-11-26 15:39 ._badger-172.gif
Successfully opened GIF badger-172.gif; Canvas size = 320 x 172
frame count: 3
duration: 150 ms
max delay: 50 ms
min delay: 50 ms
Error opening file ._badger-172.gif = 8
RP2040 and TFT, Mini GIF player "Error opening file" (black screen)
- Laila_Mestari
- mikeysklar
Re: RP2040 and TFT, Mini GIF player "Error opening file" (black screen)
Okay, I figured the locked files are part of the Ventura problem. Many devices that have been faking USB now require work arounds with Ventura. It is not anything specific to the Pi RP2040.
https://blog.adafruit.com/2022/10/31/up ... uitpython/
You should be able to push up NUKE and UF2 files via command line still with something like this (different file names).
Go ahead and enable verbose upload messages in the Arduino IDE (File --> Preferences).
The blue screen is a good sign. You are getting close. I assume the ._badger* filename is causing the issue?
$ cp -X adafruit-circuitpython-raspberry_pi_pico-en_US-7.3.3.uf2 /Volumes/RPI-RP2
- Laila_Mestari
Arduino: 1.8.19 (Mac OS X), Board: "Adafruit Feather RP2040, 8MB (no FS), 133 MHz, Small (-Os) (standard), Disabled, Disabled, Disabled, Disabled, None, Pico SDK, IPv4 Only"
Sketch uses 73804 bytes (0%) of program storage space. Maximum is 8384512 bytes.
Global variables use 33348 bytes (12%) of dynamic memory, leaving 228796 bytes for local variables. Maximum is 262144 bytes.
Resetting /dev/cu.usbmodem14201
Converting to uf2, output size: 179200, start address: 0x2000
Flashing /Volumes/RPI-RP2 (RPI-RP2)
Wrote 179200 bytes to /Volumes/RPI-RP2/NEW.UF2
processing.app.SerialException: Error opening serial port '/dev/cu.usbmodem14201'.
at processing.app.Serial.<init>(Serial.java:152)
at processing.app.Serial.<init>(Serial.java:82)
at processing.app.SerialMonitor$2.<init>(SerialMonitor.java:132)
at processing.app.SerialMonitor.open(SerialMonitor.java:132)
at processing.app.AbstractMonitor.resume(AbstractMonitor.java:132)
at processing.app.Editor.resumeOrCloseSerialMonitor(Editor.java:2126)
at processing.app.Editor.access$1300(Editor.java:116)
at processing.app.Editor$UploadHandler.run(Editor.java:2095)
at java.lang.Thread.run(Thread.java:748)
Caused by: jssc.SerialPortException: Port name - /dev/cu.usbmodem14201; Method name - openPort(); Exception type - Port not found.
at jssc.SerialPort.openPort(SerialPort.java:167)
at processing.app.Serial.<init>(Serial.java:141)
... 8 more
- Laila_Mestari
Exactly, I think the problem is related to Error opening file ._badger-172.gif = 8 line. Here is the complete message again:
Mounted filesystem!
4096 2022-11-26 17:32 ._badger-172.gif
frame count: 3
duration: 150 ms
max delay: 50 ms
min delay: 50 ms
At least now, the frame count is 3. The screen is blue since that one time when the code uploaded on the Feather without Error message. I don't know why it worked for that particular time because I believe I followed the exact same steps. Also, the screen is blue but when I connect the swtich it becomes black again.
Mounted filesystem!
frame count: 3
duration: 150 ms
max delay: 50 ms
min delay: 50 ms
- Laila_Mestari
Would it be possible to have a live troubleshooting conversation? I think it would be really helpful.
Thank you
Thank you
- mikeysklar
We don't offer live support.
MacOS creates hidden dot files when copying to external drives.
You will need to delete the dot file before uploading the Arduino code so the gif player does not get stuck on it.
- Laila_Mestari
(Sorry, I am not sure if my last message have been sent). The problem is that I did delete all dot files. What happens is that’s, as soon as the code is uploaded on the drive, it creates a dot file.
- mikeysklar
I see. Since you are exclusively using MacOS the dot file creation needs to be disabled.
You should be able to use this command to prevent MacOS from doing this:
sudo mdutil -i off -d /Volumes/RPI-RP2
sudo mdutil -i off -d /Volumes/CIRCUITPY
- Laila_Mestari
Great, thank you.
How does this command work? Do I write in as part of the code? Is it to be written on the terminal? or is it a keybard instruction?
Thank you
Thank you
- mikeysklar
The mdutil commands are to be issued at the command line ("Terminal"). The important one is the CIRCUITPY drive. That will be which is accessible after you have installed CircuitPython.
Then copy over your GIF and delete any visible dot files before uploading the Arduino code.
- Laila_Mestari
I figure out that it was on the terminal. I am still stuck at the same place: Here is what I get each time on my serial monitor:
Mounted filesystem!
4096 2022-11-29 18:18 ._badger-172.gif
frame count: 3
duration: 150 ms
max delay: 50 ms
min delay: 50 ms
Theese are the detailed steps of my process:
1
Plug RP2040 wired on breadboard with screen in the computer
2
Put RP2040 in boot loader mode
3
Clear invisible Mac files
4
Unlock locked files using TextEdit
5
"Nuke"using terminal: cp -X /Users/admin/Desktop/flash_nuke.uf2 /Volumes/RPI-RP2
6
Clear invisible Mac files again
7
Unlock files again
8
To disable dot files, type and enter on terminal:
9
Apply Circuit Python using terminal: cp -X /Users/admin/Desktop/CIRCUIT.UF2 /Volumes/RPI-RP2
10
Unlock files again
11
Clear invisible files
12
Copy GIF file on RP2040
13
14
Open Arduino 1.8.19
15
Upload code on Feather
Please let me know what else can I do
Mounted filesystem!
frame count: 3
duration: 150 ms
max delay: 50 ms
min delay: 50 ms
1
2
3
4
5
6
7
Unlock files again
8
9
10
Unlock files again
11
12
13
14
Open Arduino 1.8.19
15
- mikeysklar
Steps 12 and 13 need to be reversed.
You want to stop dot file creation before copying the GIF.
- Laila_Mestari
I just tried it out but I get the same result
- Laila_Mestari
Do you know if there is anything I can do?
- Laila_Mestari
Also, I just want to make sure of something. Did you changed the wiring or modified the DISPLAY_HEIGHT dimension in your set-up?
