Problems FT232H and Pycharm
Donic
Post by Donic »
I want to use an FT232H for an university project as part of a larger code. The development environment is Pycharm on a Windows 10 PC with Python 3.10.7. For the first tests I tried to run the "Blinking LED" example code. I have saved the environment variable 'Blinka_FT232H=1' permanently in Windows. If I call the file in the windows command prompt via 'python Test.py', it works perfectly. In Pycharm, when I call the same code using subprocesses via 'subprocesses.call(["python", "Test.py"], shell=True)', I get the error message:
File "C:\Users\User\PycharmProjects\Project\Test.py", line 6, in <module>
led1 = digitalio.DigitalInOut(board.C0)
AttributeError: module 'board' has no attribute 'C0'
I assume, it's either due to a not working properly library or because Pycharm is not running the code in Windows command prompt but in its own terminal.
Thanks for all helpful comments
adafruit_support_mike
Re: Problems FT232H and Pycharm
I'm afraid we aren't familiar with the Pycharm environment. Maybe someone from the community will have more information.
Donic
Post by Donic »
Hello Mike,
Thanks for pointing me in the right direction. I looked up Pycharm again and found an incorrect setting that was causing the error. Now the code is running and I can continue with the project.
Glad to hear you got things working. Happy hacking!
