I am having trouble using MiniMQTT with a new Raspberry Pi Pico. To start, I followed this guide here. I installed CircuitPython (8.0.0, beta 4) and was able to set up the Pi to connect to my local wifi network and ping google.com as shown in the guide.
I then switched over to this guide to set up the MQTT client and connect. This is where I run into trouble. The code I am running is:
# SPDX-FileCopyrightText: 2022 Liz Clark for Adafruit Industries
import time
import ssl
import os
import ipaddress
import wifi
import socketpool
import adafruit_minimqtt.adafruit_minimqtt as MQTT
print()
print("Connecting to WiFi")
# connect to your SSID
wifi.radio.connect(os.getenv('WIFI_SSID'), os.getenv('WIFI_PASSWORD'))
print("Connected to WiFi")
pool = socketpool.SocketPool(wifi.radio)
# prints MAC address to REPL
print("My MAC addr:", [hex(i) for i in wifi.radio.mac_address])
# prints IP address to REPL
print("My IP address is", wifi.radio.ipv4_address)
mqtt_topic = "home/CO2_val"
# Define callback methods which are called when events occur
# pylint: disable=unused-argument, redefined-outer-name
def connected(client, userdata, flags, rc):
# This function will be called when the client is connected
# successfully to the broker.
print("Connected")
# Subscribe to all changes on the onoff_feed.
#client.subscribe(onoff_feed)
def disconnected(client, userdata, rc):
# This method is called when the client is disconnected
print("Disconnected")
def message(client, topic, message):
# This method is called when a topic the client is subscribed to
# has a new message.
print("New message on topic {0}: {1}".format(topic, message))
# Create a socket pool
# Set up a MiniMQTT Client
mqtt_client = MQTT.MQTT(
broker=os.getenv('homeassistant_IP'),
port=int(os.getenv('homeassistant_port')),
username=os.getenv('homeassistant_uname'),
password=os.getenv('homeassistant_passwd'),
socket_pool=pool,
ssl_context=ssl.create_default_context(),
# Setup the callback methods above
mqtt_client.on_connect = connected
mqtt_client.on_disconnect = disconnected
mqtt_client.on_message = message
# Connect the client to the MQTT broker.
MQTT_Connected = False
print("Connecting to MQTT broker")
mqtt_client.connect()
#try:
# mqtt_client.connect()
# MQTT_Connected = True
#except:
# print("Failed to connect")
# MQTT_Connected = False
TestVal = 0
while True:
# Poll the message queue
if MQTT_Connected:
mqtt_client.loop()
# Send a new message
print("Sending value: %d..." % TestVal)
mqtt_client.publish('home/CO2_val', TestVal)
print("Sent!")
TestVal += 1
else:
print("Nothing to do...")
time.sleep(5)
]0;🐍code.py | 8.0.0-beta.4\
Connecting to WiFi
Connected to WiFi
My MAC addr: ['0x28', '0xcd', '0xc1', '0x6', '0x49', '0x5d']
My IP address is 192.168.2.36
File "code.py", line 74, in <module>
File "/lib/adafruit_minimqtt/adafruit_minimqtt.py", line 544, in connect
File "/lib/adafruit_minimqtt/adafruit_minimqtt.py", line 930, in _wait_for_msg
File "/lib/adafruit_minimqtt/adafruit_minimqtt.py", line 982, in _sock_exact_recv
MemoryError: memory allocation failed, allocating 4294955020 bytes
]0;🐍982@/lib/adafruit_minimqtt/adafruit_ MemoryError | 8.0.0-beta.4\
Code done running.
Press any key to enter the REPL. Use CTRL-D to reload.
However, this does not appear to be where the problem lies, Instead, I assume that this function should not be sent an unreasonably large buffer size. Looking at the calling function, we see the variable 'sz' is sent to that function. Adding a few debug lines to the code shows the problem:
At this point, I am sorta stuck. It looks like the code is trying to read a length from the server, receiving back a zero response, and then using that to feed a negative buffer size to the receive function. Did I mess up my code?
