pi pwm circuit
cmitcham
pi pwm circuit
Post by cmitcham »
another newbie :)
will the circuit in mike's picture above switch fast enough to use on a pi pwm pin? i need to dim a cheap string of leds. and (if so) i'm guessing with a led load, i wont need the protection diode?
thanks!
dastels
Re: pi pwm circuit
Post by dastels »
So... not that circuit?
Relays are way too slow to PWM. What LEDs are you using?
Have a look at https://learn.adafruit.com/transistors-101/example-uses. In that example I PWM a 12v LED strip to control brightness which sounds like what you want to do.
adafruit_support_mike
Re: pi pwm circuit
cmitcham wrote: Tue Nov 29, 2022 12:25 pm will the circuit in mike's picture above switch fast enough to use on a pi pwm pin?
Easily.
BJTs usually start to have trouble around 300MHz (meaning you have a specific need for the ones that operate into the gigahertz range), and power mosfets can handle 1MHz without too much trouble.
That said, Dave's right: most of a relay driver circuit is unnecessary for what you want to do. A simple power mosfet switch will be fine.
cmitcham
Re: pi pwm circuit
Post by cmitcham »
thanks!
