CircuitPython Feather I2cslave?
christofeugster
Post by christofeugster »
Hi guys
Im on a little bit bigger project with a friend.
He is programmer but unfamiliar with Python.
Im a newbie and learning CircuitPython and already owe a bunch of boards, Sensors... but am unfamiliar with C.
Now we want to split work and use a Arduino as Master and several CP Feathers as Slave, communicating over I2c.
but busio.i2cslave is not supported in CircPy.
Is there a properly working solution out?
Thanks a lot
danhalbert
Re: CircuitPython Feather I2cslave?
Post by danhalbert »
It is called busio.I2CPeripheral in CircuitPython 7.x and will be busio.I2CTarget in 8.0.0. There was an official nomenclature change. It is not supported on all boards. See https://docs.circuitpython.org/en/lates ... atrix.html for the boards it's supported on.
christofeugster
danhalbert wrote: Tue Nov 29, 2022 8:46 am It is called busio.I2CPeripheral in CircuitPython 7.x and will be busio.I2CTarget in 8.0.0. There was an official nomenclature change. It is not supported on all boards. See https://docs.circuitpython.org/en/lates ... atrix.html for the boards it's supported on.
Strange, because i also tried peripheral but it was no recognized object.
I will try again.
I asume that busio library is all i need
to actually run it? Or do i have to load something else?
Thanks for your help.
Chris
danhalbert
Which board are you trying it on? It is not on all boards.
freddyboomboom
Post by freddyboomboom »
From Dan's earlier link, if you filter on 'i2ctarget' you will see the boards that support 'i2ctarget'.
https://docs.circuitpython.org/en/lates ... =i2ctarget
If your boards do not support i2ctarget, then you'll have to find different boards that do (187 out of 353).
