Nunchuck fails on rp2040 CP 7.3.3
bbx10node
Post by bbx10node »
I have 3 nunchucks working with QT Py ESP32-S3 (5426) via the STEMMA connector. CP 7.3.3. One nunchuck is from Adafruit (PID: 342). The other two are cheap clones. The nunchuck breakout adapter (PID: 4836) is also from Adafruit.
nunchuk_simpletest.py modified to use STEMMA_I2C.
import time
import board
import adafruit_nunchuk
nc = adafruit_nunchuk.Nunchuk(board.STEMMA_I2C())
while True:
    x, y = nc.joystick
    ax, ay, az = nc.acceleration
    print("joystick = {},{}".format(x, y))
    print("accceleration ax={}, ay={}, az={}".format(ax, ay, az))
    if nc.buttons.C:
        print("button C")
    if nc.buttons.Z:
        print("button Z")
    time.sleep(0.5)
I am considering a cheaper solution using QT Py RP2040 (PID: 4900) or Trinkey QT2040 (PID: 5056) but none of the nunchucks work. All fail like this. Note all nunchucks work on the ESP32-S3 so the message is misleading.
code.py output:
  File "code.py", line 8, in <module>
  File "adafruit_nunchuk.py", line 64, in __init__
ValueError: No I2C device at address: 0x52
Based on the following forum message I modified nunchuck_simpletest.py so it works for ESP32-S3, QT Py RP2040, and Trinkey QT2040.
viewtopic.php?p=889779
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
import time
import board
i2c = board.STEMMA_I2C()
if board.board_id in ('adafruit_qt2040_trinkey', 'adafruit_qtpy_rp2040'):
    i2c.try_lock()
    i2c.scan()
    i2c.unlock()
nc = adafruit_nunchuk.Nunchuk(i2c)
while True:
    x, y = nc.joystick
    if nc.buttons.C:
        print("button C")
    if nc.buttons.Z:
        print("button Z")
    time.sleep(0.5)
adafruit_support_carter
Re: Nunchuck fails on rp2040 CP 7.3.3
Does your work around fix the issue?
Do you see any difference in behavior between the different Nunchucks?
bbx10node
Post by bbx10node »
All 3 nunchucks work the same. The workaround fixes the problem for my RP2040 boards. CP 8 does not fix the problem. I forgot which beta version I tried.
OK, sounds like you have something that'll work for your setup. The whole nunchuck protocol is reversed engineered, so may potentially have some quirks. And there appears to be minor vendor specific differences as well.
