SIGNAL: ESP-PROG -> HUZZA32
MTCK: 4 - MTCK -> 13 - MTCK
MTDI: 8 - TDI -> 12 - MTDI
MTDO: 6 - TDO -> 15 - MTDO
MTMS: 2 - TMS -> 14 - MTMS
3V: 1 - VJTAG -> 3.3V
GND: 3 - GND -> GND
I’ve modified the ESP-Prog driver to use WinUSB.
I am using the release of OpenOCD ESP32 v0.11.0 as found on github https://github.com/espressif/openocd-es ... 2-20221026.
Here are the steps I use to flash:
cd C:\openocd-esp32-win32-0.11.0-esp32-20220706\openocd-esp32\bin
openocd.exe -f ..\share\openocd\scripts\board\esp32-wrover-kit-3.3v.cfg -c "program_esp file.bin 0x10000 verify exit"
C:\openocd-esp32-win32-0.11.0-esp32-20220706\openocd-esp32\bin>openocd.exe -f ..\share\openocd\scripts\board\esp32-wrover-kit-3.3v.cfg -c "program_esp file.bin 0x10000 verify exit"
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi tdo_sample_edge falling"
Info : clock speed 20000 kHz
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
Warn : Bypassing JTAG setup events due to errors
Error: Unexpected OCD_ID = ffffffff
Warn : target esp32.cpu0 examination failed
Warn : target esp32.cpu1 examination failed
Info : starting gdb server for esp32.cpu0 on 3333
Info : Listening on port 3333 for gdb connections
Info : [esp32.cpu0] requesting target halt and executing a soft reset
Error: Target not examined yet
Info : [esp32.cpu1] requesting target halt and executing a soft reset
** Unable to reset target **
shutdown command invoked
In the pinout for the HUZZA32 it says that pin 12 is connected to a pulldown, and 14 is connected to an LED. Are these preventing the JTAG from working correctly? I would think the circuit was designed to allow this.
