I have a small Ortur Laser engraver. I want to expand the engraving from 6" square to 12" square(?) engraving area.
I purchased what I thought was the correct 4 pin connector and socket, JST PH 2.0mm set. Turns out this is not the connector/ socket type. Can anyone tell me what I have?
Thank you
Expanded Laser Engraving Area
- tcordova
- Attachments
- attachments (1).zip
- (426.77 KiB) Downloaded 4 times
- mikeysklar
Re: Expanded Laser Engraving Area
You could hold the JST-PH part you purchased up against the laser connector for reference.
If you have calipers measure the part outside diameter and pin spacing on center for the headers.
Adafruit sells a variety of JST SH pins connectors (which are smaller than PH), but I'm not sure that SH is what you need.
https://www.adafruit.com/?q=jst+sh+4-pin&sort=BestMatch
Take a look at all the options here to help determine what you have:
https://en.wikipedia.org/wiki/JST_connector
- tcordova
Thank you,
I will take your advice and post results for other.
