I search a battery for the Boost (https://www.adafruit.com/product/2465).
I already used this type of battery : https://www.distrelec.ch/fr/batterie-li ... p/30154716
This battery work great, my problem is the connector is not the same as on the Boost. So can you tell me another battery compatible or the type of the connector i need ?
Actually i solder the battery wire, but will be better if i just have to connect :)
Regards
Battery type for the Boost
Re: Battery type for the Boost
All of the LiPo cells in our store are compatible: https://www.adafruit.com/category/574
These cells are all equipped with JST-PH connectors and are wired with the correct polarity.
If purchasing batteries from a 3rd party, double check the polarity before connecting anything. There are some cells for sale that have the same JST-PH connectors - but are wired in reverse polarity.
- thefbi
OK, thank you very much.
