RPi 3,4
I use servokit with the 16 channels control board succesfully.
Does it work with the new Arducam pan tilt system with its own 2 channels control?
Thank you
Servokit with 2 channels controller
- Tannar
Re: Servokit with 2 channels controller
I cant get mine to work. What software and code did you use?
- dstonek
I’m installing a fresh Buster in Pi 4 and will try Servokit from Adafruit.
- adafruit_support_carter
You'd only want to use one controller. Either the servokit with the 16 channels or the controller that came with the Arducam. The servos being used on the Arducam appear to be generic hobby servos. And the controller appears to use a PCA9685 - so is essentially the same thing as the ServoKit 16 channel controller.
- dstonek
I've just tested them in a Pi 4 and
and it works okay but I the horizontal angle to front is 25 instead of 90. (enough for my needs)
A problem I had and solved with your help was that on reboot servos moved a bit despite angles were set the same from crontab. Solution that still works with 16 channels board was to add a non-slatching relay to cut the current to them after the angles were set.
With this new 2 channels and servos board there's no movement after reboot (or power on after power off).
import time
import sys
from time import sleep
from adafruit_servokit import ServoKit
kit = ServoKit(channels=16)
kit.servo[0].angle = 25
kit.servo[1].angle = 90
- Tannar
Is there any chance you could help me with my pca9685, it doesnt seem to want to work and i feel like ive tried everything
- dstonek
Do you mean using Arducam or Adafruit pan tilt kit?
@Tannar. Please don't cross post in other people's threads. We'll work your issue in your other thread here:
viewtopic.php?p=950388
