Sales order # 2967137-9648310759
I purchased several W25Q128 memory modules to work with an arduino nano (old bootloader). I have wired it as shown in the photographs and I am trying to run the example program in the data sheet. I note that the flash memory only accepts 3.3 V, so the Clk, MISO and MOSI output from the nano are dropped to 3.3 V using 2.2k - 3.3k voltage dividers. I have the CS pin connected to ground and the 102 and 103 pins connected to 3.3V. A photograph of the layout is attached. I have run the SdFat_format program when the example program did not work. The error message after running SdFat_format is:
Adafruit SPI Flash FatFs Format Example
Unknown flash device 0x0
Error, failed to initialize flash chip!
The error message after running the W25Q128 example is:
Initializing Filesystem on external flash...
Error: filesystem is not existed. Please try SdFat_format example to make one.
I have searched the form for similar problems, but do not find anything on this. Can you provide some suggestions on how I can proceed to get this ciruit to work? What am I missing?
W25q128 memory and arduino nano not working
- crazyleggs77
- mikeysklar
Re: W25q128 memory and arduino nano not working
Can you provide close up shots of the DIP breakout board and Nano? I can see the wiring overall, but can't quite make out the individual connections.
This is definitely a lot more complex due to the voltage dividers. You don't have to do that with the SPI Flash Breakout W25Q128 model. That or use a 3v3 based controller.
https://www.adafruit.com/product/5643
- adafruit2
CS must be connected to a GPIO pin, not graound!
