I have been able to write to the serial port window (Grand Central M4 (SAMD51 on 'COM6') in the Arduino IDE 2.0.0. I am not however able to read from this window. When I perform a Serial.available command and provide a return variable, then print this variable, it returns a 0. I know this variable changes as I initialize it as 50 when I start. It should return a 1. In Setup I use a Serial.begin(9600) and while(!Serial) command(s). I studied an Adafruit tutorial on this subject and can't seem to find a solution. Any help would be appreciated. All feedback was via the serial window within the Arduino environment. Using MS Windows 10.
Serial Read Issue
- adafruit_support_carter
Re: Serial Read Issue
available() only returns the number of bytes available for reading. You'd then call read() to actually read the value.
See basic example here:
https://www.arduino.cc/reference/en/lan ... available/
- JPF100
Thank you very much. That worked!
- JPF100
From you help, I was able to create a language independent VERY simple serial CLI to manipulate all of the DIO on the Grand Central. Onward to SPI!
- JPF100
I am now working on simple SPI interface. I have 2 GCs connected in a master/slave or controller/peripheral configuration. I am using the Arduino environment. I have been able to transmit from the controller to the peripheral, but I want to be able to read the transmitted byte from the controller on the peripheral side and display it on the peripheral's serial port console. I setup the peripheral using a series of SERCOM1 commands. This setup enables interrupts on the peripheral side of things. I successfully read back the data on the controller side. I confirmed that all of the lines are setup correctly with an oscilloscope. I also confirmed with a scope that the data being transmitted back to the controller is correct on the CIPO line with the clock. Any help would be appreciated.
