My Adafruit order number is 2966774-1539247307, ordered on Nov 25, 2022. The order was for 1 x Raspberry Pi Camera Board v2 - 8 Megapixels [ID:3099].
I followed the setup instructions on a brand new RPi 4B with the lasest Raspian as well as a RPi 3B. Neither computer detects the camera, the camera option does not show up in Preferences > Interfaces, and no lights come on on the camera PCB. I've tried multiple troubleshooting steps, reattached the camera cable numerous times, but the device appears unresponsive. I'd like to get a replacement.
Images attached.
v2 Camera not detected by RPi 4 & 3B
- testflyjets
- Attachments
- camera_pcb.jpg (964.53 KiB) Viewed 75 times
- camera_cable.jpg (652.07 KiB) Viewed 75 times
- camera.jpg (713.59 KiB) Viewed 75 times
- bidrohini
Re: v2 Camera not detected by RPi 4 & 3B
You can find some tips here: https://forums.raspberrypi.com/viewtopic.php?t=327075
- testflyjets
Can you confirm for me what qualifies as needing "legacy camera" support? I have a v2 Pi cam, which is, I think, the latest they offer. Do I need to enable legacy camera support in a Pi 4B for a v2 camera to operate?
- adafruit_support_carter
Can you clarify where this is happening? Is this in raspi-config? And there's no camera related option under "Interface Options"?the camera option does not show up in Preferences > Interfaces
What OS image are you using?
- testflyjets
These instructions indicate that if a camera is connected to the Pi, I should see a Camera option in the Raspberry Pi Preferences > Interfaces section: https://projects.raspberrypi.org/en/pro ... picamera/2
However, there is no Camera option shown when I check this on the Pi 4B.
I have reinserted the camera cable very carefully multiple times on this board and my older Pi 3B with no luck.
raspi-config offers the option to enable/disable "legacy camera support," however, as I mentioned in the thread above, it's not clear to me why I would choose that if I have the newest v2.1 Pi cam.rasp
See attached screenshot showing raspi-config and the Preferences Interfaces panel.
The OS version, as shown in the 'about' section of raspi-config, is: 20221018. I downloaded the most recent raspian last week from https://www.raspberrypi.com/software/
- Attachments
- raspi-config.png (208 KiB) Viewed 58 times
Thanks for the screenshots and clarification. Some of this seems related to recent changes with camera support in the latest Raspberry Pi OS releases. There's a big blog post about it here:
https://www.raspberrypi.com/news/bullse ... ra-system/
It's very different now. So some documentation may be out of date. With the new setup, there's no longer an "enable the camera" step.
Try opening a command window and running one of the new libcamera commands.
Here's a simple one that can be used to check if the camera is connected:
It should output something like this:
libcamera-still --list-cameras
pi@raspberrypi:~ $ libcamera-still --list-cameras
Available cameras
0 : ov5647 [2592x1944] (/base/soc/i2c0mux/i2c@1/ov5647@36)
Modes: 'SGBRG10_CSI2P' : 640x480 [58.92 fps - (16, 0)/2560x1920 crop]
1296x972 [43.25 fps - (0, 0)/2592x1944 crop]
1920x1080 [30.62 fps - (348, 434)/1928x1080 crop]
2592x1944 [15.63 fps - (0, 0)/2592x1944 crop]
- testflyjets
Thanks, I'm happy to report I've got things working now. The instructions to enable the camera in the Interfaces section really threw me, and the article you linked to was very enlightening.
