70mm cool white led ring
Bradenandrey
Post by Bradenandrey »
I saw while reading about this led ring light. That it will need a heat sink for it. I was wondering where and what is the proper size heat sink for it.
dastels
Re: 70mm cool white led ring
Post by dastels »
A heatsink is one option:
Please note, this ring has a lot of LEDs on it and since its not in a heatsink case it will get hot - if you want to keep it on for more than a minute, either add a heatsink, PWM it or drive it at a lower voltage by adding a diode or resistor in series to reduce the current.
So you only have to worry if it's going to be on for more that a minute at a time. You can add a heatsink or reduce the amount of power being dissipated but using a lower voltage or by PWMing so the average power used is less.
I don't know about heatsinks, it largely depends on the situation. Sticking it to a piece of metal would be the most straight forward, being careful about the connection on the back.
As an alternative, have a look at https://www.adafruit.com/product/4433, which is similar and does have a heatsink as part of it.
Bradenandrey
Thanks Dave for the reply. I saw that light before but this one is perfect for my project. I was hoping to have the lights on for about 5-6 hours. So I figured a Heatsink is a must.
dastels
Post by dastels »
Yes, that will generate quite a bit of heat over that time. Maybe a fan blowing across the heatsink as well?
Return to “Arduino”
