MPR121 code only runs when connected to arduino software
Drc3p0_0
Post by Drc3p0_0 »
I am using a Teensy microcontroller set as a MIDI usb device, which sends MIDI messages when one of the MPR121 sensor inputs detects a touch. The code works, but the issue is that it only seems to work when it is actively connected to the Arduino IDE. When connected to the Arduino IDE, I see the serial messages, the LED turns on when touch is detected, and I see the appropriate MIDI messages in my Midi Monitor software. If I close arduino, unplug it, and plug it back in, it no longer works (no midi messages being detected even when there is a verified connection to the teensy, and no LED turning on when touched).
I'm guessing there's something with the code that it needs to be detected via serial monitor for the code to run, and I would like to figure out how to omit that from the code so that it can work as a MIDI usb device when plugged into my computer with the Arduino IDE closed.
Thanks in advance, I'm so stumped and would love to figure this out.
This is a library for the MPR121 12-channel Capacitive touch sensor
Designed specifically to work with the MPR121 Breakout in the Adafruit shop
  ----> https://www.adafruit.com/products/
These sensors use I2C communicate, at least 2 pins are required
to interface
products from Adafruit!
//sketch in progress.  trying to read i2c from mpr121 and send midi message from teensy in response to which pin is touched.
//important links: teensy wire library: https://www.pjrc.com/teensy/td_libs_Wire.html
// teensy midi library: https://www.pjrc.com/teensy/td_midi.html
//current issues: doesn't work once unplugged and plugged back in.  only works when connected to the Arduino serial monitor
#include <Wire.h>
#include "Adafruit_MPR121.h"
#ifndef _BV
#define _BV(bit) (1 << (bit))
#endif
// You can have up to 4 on one i2c bus but one is enough for testing!
Adafruit_MPR121 cap = Adafruit_MPR121();
// Keeps track of the last pins touched
// so we know when buttons are 'released'
uint16_t lasttouched = 0;
uint16_t currtouched = 0;
const uint8_t numElectrodes = 12; //added by drc
const uint8_t notes[numElectrodes] = {36, 38, 40, 43, 45, 47, 48, 50, 52, 55, 57, 60}; //added by drc
int channel = 1; //added by drc
  Wire.begin(0x5A); //added by drc
  Serial.begin(9600);
  pinMode(LED_BUILTIN, OUTPUT); //added by drc
  Wire.setSDA(18); //use a 4.7k pullup resistor //added by drc
  Wire.setSCL(19); //use a 4.7k pullup resistor //added by drc
  while (!Serial) { // adding a delay to avoid issues seen in other forum posts.
    delay(10);
  Serial.println("Adafruit MPR121 Capacitive Touch sensor test");
  // Default address is 0x5A, if tied to 3.3V its 0x5B
  // If tied to SDA its 0x5C and if SCL then 0x5D
  if (!cap.begin(0x5A)) {
    Serial.println("MPR121 not found, check wiring?");
    while (1);
  Serial.println("MPR121 found!");
  // Get the currently touched pads
  currtouched = cap.touched();
  for (uint8_t i=0; i<numElectrodes; i++) { //changed i<0 to i<numElectrodes
    // it if *is* touched and *wasnt* touched before, alert!
    if ((currtouched & _BV(i)) && !(lasttouched & _BV(i)) ) {
      digitalWrite (LED_BUILTIN, HIGH); //added by drc
      usbMIDI.sendNoteOn(notes[i], 127, channel); // added by drc
      Serial.print(i); Serial.println(" touched");
    // if it *was* touched and now *isnt*, alert!
    if (!(currtouched & _BV(i)) && (lasttouched & _BV(i)) ) {
      digitalWrite (LED_BUILTIN, LOW);
      usbMIDI.sendNoteOff(notes[i], 127, channel); // maximum velocity
      Serial.print(i); Serial.println(" released");
  // reset our state
  lasttouched = currtouched;
  // comment out this line for detailed data from the sensor!
  return;
  // debugging info, what
  Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t\t 0x"); Serial.println(cap.touched(), HEX);
  Serial.print("Filt: ");
  for (uint8_t i=0; i<12; i++) {
    Serial.print(cap.filteredData(i)); Serial.print("\t");
  Serial.println();
  Serial.print("Base: ");
    Serial.print(cap.baselineData(i)); Serial.print("\t");
  Serial.println();
  // put a delay so it isn't overwhelming
  delay(100);
void noteOn(uint8_t channel, uint8_t pitch, uint8_t velocity) {
	usbMIDI.sendNoteOn(notes[numElectrodes], velocity, channel); //notes changed to [numElectrodes] by drc
void noteOff(uint8_t channel, uint8_t pitch, uint8_t velocity) {
	usbMIDI.sendNoteOff(notes[numElectrodes], velocity, channel);
dastels
Re: MPR121 code only runs when connected to arduino software
Post by dastels »
It's likely getting hung up looking for a connection:
    delay(10);
Try commenting out, deleting, or conditionally compiling any mention/use of Serial.
Drc3p0_0
Post by Drc3p0_0 »
dastels wrote: Mon Dec 05, 2022 10:28 am It's likely getting hung up looking for a connection:
    delay(10);
That fixed it! Thank you so much!
Return to “Arduino”
