There was another thread, about seven years ago, on this issue. However, it is plaguing me now. I am using a known good data cable. I am able to send sketches to a Micro using the same cable.
Following the directions here, I was able to get Adafruit 32u4 Breakout to show up in the board manager. However, there is still no com port assigned.
Windows not recognizing Adafruit Feather 32u4 RFM96 LoRa Radio - 433MHz
- Robert_C
- mikeysklar
Re: Windows not recognizing Adafruit Feather 32u4 RFM96 LoRa Radio - 433MHz
What version of Windows are you running?
You were following the Feather M0 instructions, but you have a 32u4 RFM96. This board needs the SiLabs and FTDI driver installed.
https://learn.adafruit.com/adafruit-fea ... ly-2854751
- Robert_C
I am running:
Edition Windows 10 Home Single Language
Version 21H2
Installed on 11/14/2020
OS build 19044.2251
Experience Windows Feature Experience Pack 120.2212.4180.0
I will have to check what I am running at work and post that tomorrow.
Version 21H2
OS build 19044.2251
- mikeysklar
Okay, so Win10 might not need the driver, but since you are having and the documentation can be read either way make sure you try installing the drivers.
