I am using ATmega256 (usartA0)to read temperature from MAX31865 with a 2 wired pt100. The msb and lsb are zeros.
The pt100 is measured 108ohms. Then I used a 118ohms resistor, it still reads zero. I took the resistor out, leave it break, it still reads zero.
I tried both one-shot, or automode, it does not change anything. The basic codes are listed below. I have stuck with this max31865 for a week now. Really run out of ideas now.
Any advice will help? Thanks a lot.
#define USART_MAX3186 &USARTA0
#define MAX3186_0_CS IOPORT_CREATE_PIN(PORTB,4) //1 E,3;D,7
#define MAX3186_1_CS IOPORT_CREATE_PIN(PORTB,2) //D,5
#define MAX3186_DRDY0 IOPORT_CREATE_PIN(PORTB,5) //3
#define MAX3186_DRDY1 IOPORT_CREATE_PIN(PORTB,6) //4
//Registers defined in Table 1 on page 12 of the datasheet
#define READ_CONFIGURATION 0x00 //0b00000000 // 0x00H
#define WRITE_CONFIGURATION 0x80 //0b10000000 // 0x80H
#define READ_RTD_MSB 0x01 //0b00000001 // 0x01H
#define READ_RTD_LSB 0x02 //0b00000010 // 0x02H
#define READ_HIGH_FAULT_TRESHOLD_MSB 0x03 //0b00000011 // 0x03H
#define WRITE_HIGH_FAULT_TRESHOLD_MSB 0x83 //0b10000011 // 0x83H
#define READ_HIGH_FAULT_TRESHOLD_LSB 0x04 //0b00000100 // 0x04H
#define WRITE_HIGH_FAULT_TRESHOLD_LSB 0x84 //0b10000100 // 0x84H
#define READ_LOW_FAULT_TRESHOLD_MSB 0x05 //0b00000101 // 0x05H
#define WRITE_LOW_FAULT_TRESHOLD_MSB 0x85 //0b10000101 // 0x85H
#define READ_LOW_FAULT_TRESHOLD_LSB 0x06 //0b00000110 // 0x06H
#define WRITE_LOW_FAULT_TRESHOLD_LSB 0x86 //0b10000110 // 0x86H
#define FAULT_STATUS 0x07 //0b00000111 // 0x07H
#define CONFIG_FAULTSTAT 0x02 //0b0000 0010 set D1 in the configuration reg. to clear all faults
void max_clear_fault(uint8_t max3186_pt_id)
uint8_t config;
/*"""Clear any fault state previously detected by the sensor."""*/
usart_spi_select_device(USART_MAX3186, &max3186[max3186_pt_id]);
/*Write RTD DATA register*/
usart_spi_write_packet(USART_MAX3186,&READ_CONFIGURATION_ADDRESS,1);
usart_spi_read_packet(USART_MAX3186,&config,1);
usart_spi_deselect_device(USART_MAX3186, &max3186[max3186_pt_id]);
config &= ~0x2C;
config |= CONFIG_FAULTSTAT;
usart_spi_write_packet(USART_MAX3186,&WRITE_CONFIGURATION_ADDRESS,1);
usart_spi_write_packet(USART_MAX3186,&config,1);
void max_config_one_shot(uint8_t max3186_pt_id)
uint8_t config;
delay_us(10);
config|=CONFIGURE_ONE_SHOT[1];
void max_config_automode(uint8_t max3186_pt_id)
uint8_t config;
delay_us(10);
config|=CONFIGURE_AUTOMODE[1];
// Reading data from max
uint16_t max_get_data(uint8_t max3186_pt_id,ioport_pin_t DRDY_PIN)
In normal operation function returns RTD or temperature multiplexed by 10
If new conversion result is not available - DRDY is high, wait to ready
uint8_t lsb_rtd, msb_rtd;
uint8_t DRDY_state;
uint16_t RTD, lmsb;
while(DRDY_state){DRDY_state=ioport_get_pin_level(DRDY_PIN);}
usart_spi_write_packet(USART_MAX3186,&READ_RTD_MSB_ADDRESS,1);
/*Read out ODR register*/
// usart_spi_read_packet(USART_MAX3186,&msb_rtd,1);
// delay_us(1);
// usart_spi_write_packet(USART_MAX3186,&READ_RTD_LSB_ADDRESS,1);
// /*Read out ODR register*/
// usart_spi_read_packet(USART_MAX3186,&lsb_rtd,1);
// delay_us(1);
usart_spi_read_packet(USART_MAX3186,&lmsb,2);
/*Pull chip select high to finish SPI transfer*/
_delay_ms(1);
// msb_rtd=lmsb>>8;
// lsb_rtd=lmsb&0xFF;
// lsb_rtd = max_spi_read(READ_RTD_LSB);
// msb_rtd = max_spi_read(READ_RTD_MSB);
// RTD = (msb_rtd << 7)+((lsb_rtd & 0xFE) >> 1);
// RTD =((lmsb<<8)|((lmsb>>8)&0xFE))>>1;
// RTD = (msb_rtd << 8)+lsb_rtd;
RTD=lmsb;
// Basic temperature calculation, the accuracy for temperatures
// between -75°C - 100°C is max +-1.5°C
// *temperature = (float) RTD / 32 - 256; //(10*RTD)>>5 - 2560; // (10*RTD>>5) - 2560; //RTD / 32 - 256
/*Initializes accelerometer by setting the operating mode and testing the port for proper data output*/
uint8_t initialize_max3186_pt1000(uint8_t max3186_pt_id)
uint8_t conf=0;
max3186[max3186_pt_id].id = max3186_ids[max3186_pt_id];
/*If the system is configured using , set up the devices with a SPI mode 3 clock (CPOL 1, CPHA 1) as specified in the datasheet*/
usart_spi_setup_device(USART_MAX3186,&max3186[max3186_pt_id],CPOL_1_CPHA_1, MAX3168_BAUD_RATE,&max3186[max3186_pt_id].id);
delay_us(1);
max_clear_fault(max3186_pt_id);
usart_spi_write_packet(USART_MAX3186,&CONFIGURE_BIAS,2); //TURN ON BIAS
_delay_ms(15); //wait for max to power up and stablize 11.5ms
max_config_automode(max3186_pt_id);
_delay_ms(65);
// Reading Configuration register to verify communication
/*Write address ofReading*/
/*Read out configuration register*/
usart_spi_read_packet(USART_MAX3186,&conf,1);
watch_conf=conf;
if((conf & 0b10000000)==0x80)
return 1;
else
return 0;
/*Reads max31865*/
void measure(float *temperature_measured)
uint16_t RTDM;
uint8_t max_connected, conf, conf1, Fault_Error;
float pt1000_temp;
ioport_configure_pin(max3186_ids[0],IOPORT_DIR_OUTPUT|IOPORT_INIT_HIGH|IOPORT_MODE_PULLUP);
ioport_configure_pin(max3186_ids[1],IOPORT_DIR_OUTPUT|IOPORT_INIT_HIGH|IOPORT_MODE_PULLUP);
ioport_configure_pin(MAX3186_DRDY0,IOPORT_DIR_INPUT|IOPORT_INIT_LOW|IOPORT_MODE_PULLDOWN);
ioport_configure_pin(MAX3186_DRDY1,IOPORT_DIR_INPUT|IOPORT_INIT_LOW|IOPORT_MODE_PULLDOWN);
/*Initialize USART SPI Options*/
usart_opts.baudrate = USART_SPI_BAUDRATE; //Baud rate
usart_opts.data_order = 0; //Standard-ordered data
usart_opts.spimode = CPOL_1_CPHA_1; //Clock polarity set to "base state high" and clock phase set to "capture on rising edge"
/*Initialize SPI using options set above*/
usart_init_spi(USART_MAX3186,&usart_opts);
/*Enable USART Module for data collection using SPI.*/
usart_spi_enable(USART_MAX3186);
/*Wait for Max31865 to boot*/
_delay_ms(65);
/*Model-specific parameter initialization*/
for(int i=0;i<NUM_TEMP_SENSORS;i++)
max_connected=initialize_max3186_pt1000(i);
if(max_connected==0)
// /*if not connected, then clear fault, and re-initialize it* /
initialize_max3186_pt1000(i);// Initializes communication with max
RTDM=max_get_data(i, MAX_DRDY[i]);
// RTD=(RTD>>8)|(RTD<<8);
if ((RTDM & 0x01) == 0) // No fault
//RTD = (msb_rtd << 7)+((lsb_rtd & 0xFE) >> 1);
temperature_measured[i]=(float) (RTDM>>1) / 32 - 256 +t_offset[i];
// Any fault have been detected
else
temperature_measured[i] = 88.88;
usart_spi_select_device(USART_MAX3186, &max3186[i]);
usart_spi_write_packet(USART_MAX3186,&CONFIGURE_FAULT,1);
Fault_Error=conf;
usart_spi_deselect_device(USART_MAX3186, &max3186[i]);
