I recently completed a project which utilizes the Matrix Portal (64x32 RGB display with ATSAMD51J19 Cortex M4). Using the I2C connector, I implemented support in my code for a Neopixel 1x4 keyboard.
When assembling the portal and keyboard, I observed that if I used any STEMMA QT / Qwicc cable longer than 50mm I would see periodic crashes. After a crash and resetting the board I would get the message "No pull up found. Check your wiring". If I turned the unit off, unplugged and plugged the same cable back it, it would work for a period of time. Also, any movement in the cable would result in the crash.
I've reworked the project to use a side mounted keyboard and 50mm cable. And it has been stable. However, it would be nice to be able to use a longer cable length.
I tried the following cables:
JST SH 4-Pin cable - 200mm (part 4401)
JST SH 4-Pin cable - 50mm (part 4399)
STEMMA QT/Qwicc cables - 100mm, 200mm (alternate manufacturer)
Build-your-own STEMMA QT/Qwicc cables - precrimped, 100mm
I looked over the documentation, and asked in Discord, but I could find nothing that indicated why anything longer than 50mm in length would cause this instability.
I tried two different boards (ATSAMD51J19 Cortex M4) and two different Neopixel 1x4 keyboards and observed the same behavior.
Does anyone have an idea why this happens?
Thanks,
Nicole
Matrix Portal M4 with I2C Neopixel 1x4 Keyboard
- ntynen
- johnpark
Re: Matrix Portal M4 with I2C Neopixel 1x4 Keyboard
I'm not sure why that's behaving that way, but I'd be curious if an active terminator would improve the cable length options. https://www.adafruit.com/product/4756
- ntynen
Thanks for this information! I've added one to my cart for the next shopping trip. :) After I run some tests I'll let you know how it goes.
