Using PlatformIO, I have been able to get Arduino-based projects to build, upload, and boot just fine. However, when I tried to do the same with the "esp-idf hello world" example project I was only able to build and flash. When I reset the board after flashing, the COM port disappears and does not reconnect. I can get the COM port back by putting the board into "manual bootloader" mode.
Knowing the bootloaders are different between the Arduino and ESP-IDF projects, I tried erasing the flash before programming, but this did not work either.
I added this
[env:adafruit_qtpy_esp32s2]
platform = espressif32
board = adafruit_qtpy_esp32s2
framework = espidf
platformio.ini
pio run -e adafruit_qtpy_esp32s3 --target upload
Does anyone have any experience getting the QT PY ESP32-S2 working via ESP-IDF (either standalone or via PlatformIO)?
