I work with an Arduino mega and an adafruit music maker.
I posted few days ago for a problem with the sound that wouldn't stop and I figured out why, but know I have another issue with my set up.
With my code I play a song when there is an error in my task (more precisely, when I push a button, cf picture in links below and code below) until a detector is LOW once (departure detector, at the end of the code).
But there is a problem while playing the error sound, when I press the button in the first trial it works properly but then if another trial begins and there is another error and I press the button, the sound play, make a micropause, and then continue.
Here is my code:
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// These are the pins used for the breakout example
#define BREAKOUT_RESET 9 // VS1053 reset pin (output)
#define BREAKOUT_CS 10 // VS1053 chip select pin (output)
#define BREAKOUT_DCS 8 // VS1053 Data/command select pin (output)
// These are the pins used for the music maker shield
#define SHIELD_RESET -1 // VS1053 reset pin (unused!)
#define SHIELD_CS 7 // VS1053 chip select pin (output)
#define SHIELD_DCS 6 // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 4 // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 3 // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
// create breakout-example object!
//Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
// create shield-example object!
Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS); // these are all variables state above
//pins for the task
const int pinDepart = 22; // pin departure detector
const int pinReward = 24; // pin arrival detector
const int pinPompe = 26; // pin arrival reward
const int pinPompe2 = 28; // pin departure reward
const int pinButton = 30; //pin button error (pressed when there is an error)
const int pinButtonporte = 32; //pin button departure door
const int pinBruit = 34; //pin light when there is an error (when the button is pressed)
// Door reward
const int stepPin = 31;
const int dirPin = 33;
const int enPin = 35;
// Door reward 2
const int stepPin2 = 37;
const int dirPin2 = 39;
const int enPin2 = 35;
// Declaring state variables
int s_a, e_a, b_a, s_p; //s_a : dectector departure activated, e_a : detector arrival activated
//s_p: door departure open, b_a : button error pressed
int state;
unsigned long int timing;
// Allowance variables
int sia, eia; //sia : detector departure can be activated, eia: detector arrival can be detected
// Pump variables
const float delayPump = 30; // ms
Serial.begin(9600);
musicPlayer.begin();
SD.begin(CARDCS);
musicPlayer.setVolume(40, 40);
musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT);
pinMode(pinDepart, INPUT);
pinMode(pinReward, INPUT);
pinMode(pinButton, INPUT_PULLUP);
pinMode(pinButtonporte, INPUT_PULLUP);
pinMode(stepPin, OUTPUT);
pinMode(dirPin, OUTPUT);
pinMode(enPin, OUTPUT);
pinMode(stepPin2, OUTPUT);
pinMode(dirPin2, OUTPUT);
pinMode(enPin2, OUTPUT);
pinMode(pinPompe, OUTPUT);
pinMode(pinPompe2, OUTPUT);
pinMode(pinBruit, OUTPUT);
digitalWrite(enPin, LOW);
digitalWrite(enPin2, LOW);
s_a = 0;
e_a = 0;
b_a = 0;
s_p = 0;
sia = 1;
eia = 0;
void release_reward(int delayPump, int pinPompe) {
delay(delayPump);
digitalWrite(pinPompe, HIGH);
delay(delayPump / 2);
digitalWrite(pinPompe, LOW);
void release_reward_loop(int delayPump, int pinPompe, int n_releases) {
int i;
for (i = 0; i < n_releases; i++) {
release_reward(delayPump, pinPompe);
void move_door(int closedoor, int dirPin, int stepPin, int port) {
int d = 50;
if (port == 0) {
d = 55;
int msg = HIGH;
if (closedoor) {
msg = LOW;
for (int x = 0; x < 16.4 * 1600; x++) {
digitalWrite(dirPin, msg); // Enables the motor to move in a particular direction
digitalWrite(stepPin, HIGH);
delayMicroseconds(d);
digitalWrite(stepPin, LOW);
if (s_p == 0) {
if (digitalRead(pinButtonporte) == HIGH) { //If I opened the door then:
move_door(0, dirPin2, stepPin2, 0);
timing = millis();
Serial.print("Detecteur_depart_aller, debut trial");
Serial.print(",");
Serial.println(timing);
s_p = 1; //door is open
s_a = 1; //departure detector has been activated
eia = 1; // arrival detector can be detected
sia = 0; // departure detector cannot be detected anymore
} else {
if (b_a == 0) { //if no error
state = digitalRead(pinReward);
if (state == LOW) { //if arrival detector activated
if (s_a == 1 && e_a == 0 && eia == 1) {
timing = millis();
Serial.print("Detecteur_arrivee, fin aller");
Serial.print(",");
s_a = 1;
e_a = 1;
eia = 0;
sia = 1;
musicPlayer.startPlayingFile("rewardsd.wav"); //a sound cause the trial is correct
move_door(1, dirPin, stepPin, 1); //door is moving
delay(2000);
release_reward_loop(delayPump, pinPompe, 10); //reward is released
delay(1000);
move_door(0, dirPin, stepPin, 1); //door is moving again
timing = millis();
Serial.print("Detecteur_arrivee, debut retour");
Serial.print(",");
state = digitalRead(pinDepart);
if (state == LOW) { //if departure dectector is activated
if (s_a == 1 && e_a == 1 && sia == 1) { // if the task has been completed :
s_a = 0;
e_a = 0;
timing = millis();
Serial.print("Detecteur_depart_retour, fin trial");
Serial.print(",");
move_door(1, dirPin2, stepPin2, 0); //door is closing
delay(1000);
release_reward_loop(delayPump, pinPompe2, 10); //reward
s_p = 0; //door closed
if (digitalRead(pinButton) == HIGH) { //if there is an error (I pressed the button)
b_a = 1; //button is pressed
digitalWrite(pinBruit, HIGH); //light is ON
timing = millis();
Serial.print("Debut erreur");
Serial.print(",");
} else if (b_a == 1) { //if button is active
eia = 0; // arrival detector can't be detected anymore
if (state == HIGH) {
musicPlayer.startPlayingFile("errorsnd.wav"); //play error sound until detector is low 1 time
} else if (state == LOW) { // if the depature detector has been activated once
musicPlayer.stopPlaying(); //stop the sound
digitalWrite(pinBruit, LOW); //the light is OFF now
timing = millis();
Serial.print("end");
Serial.print(",");
s_p = 0; //door is closed
sia = 1; //everything is set to do a new trial
s_a = 0;
b_a = 0;
https://upload.wikimedia.org/wikipedia/ ... om-min.jpg
https://upload.wikimedia.org/wikipedia/ ... no-min.jpg
I don’t understand why I have this pause!
Can you help me with that?
Thanks!!
