Trinket M0 SPI minimum baudrate
g3cko
Post by g3cko »
Does the M0 have a limited set of supported baudrates for SPI, or am I using this wrong or misunderstanding things?
I am using circuit python (7.x) and it seems like this param has a minimum supported value, but I can't quite understand "why" that is, or if there is a work around.
I am trying to interface with another device that uses a proprietary 3-wire SPI and need a slower rate here (roughly half the speed of this).
import board
import busio
import digitalio
from adafruit_bus_device.spi_device import SPIDevice
SPI = busio.SPI(board.SCK, MOSI=board.MOSI)
while True:
    device = SPIDevice(SPI, cs, baudrate=2400)
    print('writing...', count)
    count += 1
    with device as spi:
        # 68 65 6C 6C 6F 20 77 6F 72 6C 64
        spi.write(b'hello world')
    time.sleep(2.0)
# couple prints in spi_device.py
print(':', self.baudrate)
print(':', self.spi.frequency)
# example output
writing... 0
: 2400
: 93750
