I am working on a project that involves amplifying low voltage (~ 2.5 mV) signals and registering them with a timestamp using Arduino UNO. So far I have been able to run successfully the ADS1115 and print on the serial monitor data.
I am using the Adafruit library for the ADS:
#include <Adafruit_ADS1X15.h>
#include <RTClib.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
In order to register the information I intend to use an old Adafruit Datalogger Shield with RTC (1307) and an SD card slot.
Both components run perfectly one at the time, but when I intend to run both to log the data the Arduino simply freezes. I read about a conflicts between RTC1307 and ADS1115 that use the I2C bus protocol. I have already checked for a possible conflict regarding the addresses of the devices, but according to this old thread (viewtopic.php?t=78413) it seems the addresses do not coincide and therefore should not be a problem. The thread is actually locked and some other posts I found mention about hacking both the shield and the libraries, but so far, I decided to post this here in order to receive feedback.
Thanks in advance to everybody.
AGT
