Adafruit ItsyBitsy nRF52840 Express not pairing with mobile app
dolsen_RPi
Re: Adafruit ItsyBitsy nRF52840 Express not pairing with mobile app
Post by dolsen_RPi »
Thank you for your response.
I had to put this down for a few days, but I have now gone through the process of (at least attempting to) burn the bootloader into each board, per your recommendation. It looks like it worked; although sometimes the Arduino IDE log just showed a message that the firmware was being programmed and did not mention anything to do with the bootloader being uploaded even though I specifically chose the option to burn the bootloader each time. I assume is because the bootloader in the tool must have the same checksum as the one on the board, but I could be mistaken.
At any rate, unfortunately, the result is the same. I still can't pair with the board. It's bizarre. I have purchased many of these boards in the past, and they have all worked fine up to now.
Any other ideas?
hathach
Post by hathach »
dolsen_RPi wrote: Thu Dec 15, 2022 5:04 pm Thank you for your response.
Sorry for late response, you only need to click "Burn bootloader" once per board to upgrade bootloader. Afterwards, you could check the bootloader version in the ITSY840BOOT/INFO_UF2.TXT, it should show the version 0.6.2 as follows
UF2 Bootloader 0.6.2 lib/nrfx (v2.0.0) lib/tinyusb (0.10.1-293-gaf8e5a90) lib/uf2 (remotes/origin/configupdate-9-gadbb8c7)
Model: Adafruit ItsyBitsy nRF52840 Express
Board-ID: nRF52840-ItsyBitsy-revA
SoftDevice: S140 version 6.1.1
Date: Sep 10 2021
dolsen_RPi wrote: Thu Dec 15, 2022 5:04 pm At any rate, unfortunately, the result is the same. I still can't pair with the board. It's bizarre. I have purchased many of these boards in the past, and they have all worked fine up to now.
Any other ideas?
I take another look at your compile log, look like you used an old set of libraries and IDE (1.8.13). Maybe try to upgrade IDE to 1.8.19 and upgrade all the libraries to their latest and give it a try again
Using library Adafruit_TinyUSB_Arduino at version 1.7.0 in folder: C:\Users\dave_\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.3.0\libraries\Adafruit_TinyUSB_Arduino
Using library Adafruit_MCP23017_Arduino_Library at version 2.1.0 in folder: C:\Users\dave_\Documents\Arduino\libraries\Adafruit_MCP23017_Arduino_Library
Using library Adafruit_BusIO at version 1.11.3 in folder: C:\Users\dave_\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 1.0 in folder: C:\Users\dave_\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.3.0\libraries\Wire
Using library SPI at version 1.0 in folder: C:\Users\dave_\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.3.0\libraries\SPI
Using library Bluefruit52Lib at version 0.21.0 in folder: C:\Users\dave_\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.3.0\libraries\Bluefruit52Lib
Using library Adafruit_BANNED at version 0.0.5 in folder: C:\Users\dave_\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.3.0\libraries\Adafruit_BANNED
Using library Adafruit_LittleFS at version 0.11.0 in folder: C:\Users\dave_\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.3.0\libraries\Adafruit_LittleFS
Using library InternalFileSytem at version 0.11.0 in folder: C:\Users\dave_\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.3.0\libraries\InternalFileSytem
Using library Adafruit_DS3502 at version 1.0.1 in folder: C:\Users\dave_\Documents\Arduino\libraries\Adafruit_DS3502
Return to “Microcontrollers”
