My daughter got her Circuit Playground Bluefruit. She’s playing with it with MakeCode Maker editor. I know support is still in beta but just wanted to let you know what we see. She’s all very exited but there is some issue with sound output. It plays ok only right after putting the code on the device. After a reset (or power cycle) the speaker just makes a silent buzz. You can see and hear it on the clip I’ve made
https://share.icloud.com/photos/049uMKD ... uU1Po2lLcg
Any ideas why this happens? Can we fix it with upgrade or something?
The code generated it like this
def on_button_b_long_click():
music.set_volume(125)
music.power_up.play_until_done()
if input.button_b.was_pressed():
pause(1000)
light.set_brightness(25)
light.set_all(0x007fff)
pause(1000)
light.set_all(0x7f00ff)
pause(1000)
light.set_all(0xff00ff)
pause(1000)
light.set_all(0xff9da5)
pause(1000)
light.set_brightness(0)
input.button_b.on_event(ButtonEvent.LONG_CLICK, on_button_b_long_click)
def on_button_a_click():
light.set_brightness(20)
light.default_strip().set_gradient(0xff0000, 0xffff00)
music.play_melody("B A G A A B G B ", 450)
music.play_melody("F E D E E F D F ", 450)
input.button_a.on_event(ButtonEvent.CLICK, on_button_a_click)
def on_gesture_shake():
def on_run_in_parallel():
music.play_melody("G A A G A B B A ", 240)
light.default_strip().set_pixel_color(0, 0xff0000)
pause(100)
light.default_strip().set_pixel_color(1, 0xff8000)
pause(100)
light.default_strip().set_pixel_color(2, 0xffff00)
pause(100)
light.default_strip().set_pixel_color(3, 0xff9da5)
pause(100)
light.default_strip().set_pixel_color(4, 0xb09eff)
pause(100)
light.default_strip().set_pixel_color(5, 0x7f00ff)
pause(100)
light.default_strip().set_pixel_color(6, 0xff00ff)
pause(100)
light.default_strip().set_pixel_color(7, 0xff0080)
pause(100)
light.default_strip().set_pixel_color(8, 0xff8000)
pause(100)
light.default_strip().set_pixel_color(9, 0xff0000)
pause(2000)
control.run_in_parallel(on_run_in_parallel)
input.on_gesture(Gesture.SHAKE, on_gesture_shake)
