Running PWM Servo FeatherWing By Itself
Latinsk8er
Post by Latinsk8er »
So I am completely new to microcontrollers and this type of stuff in general. I want to control one to two servos for an animatronic and I came across the PWM Servo FeatherWing. So I quickly ordered it and now that I have it, I am lost. I may have misunderstood when the description said "You can stack it with any other FeatherWing or with itself (just make sure you have each wing with a unique I2C address)", as meaning that I only needed the FeatherWing to control the servos. But now that I have it in my hand, I am pretty sure I need a Feather or Arduino or something similar. I am lost in this awesome word of microcontrollers and electronics. I have not idea how, once I figure out the code, I would transfer it to the FeatherWing. Any help would be appreciated. Like I said, this is my first step into this. Thanks.
Re: Running PWM Servo FeatherWing By Itself
The PWM Servo Wing requires a microcontroller to control it. It is designed to plug directly into any of the Feather microcontroller boards. It could also be attached to most other microcontrollers via jumpers.
See the documentation for the Wing here: https://learn.adafruit.com/adafruit-8-c ... eatherwing
Latinsk8er
adafruit_support_bill wrote: Mon Dec 19, 2022 1:19 pm The PWM Servo Wing requires a microcontroller to control it. It is designed to plug directly into any of the Feather microcontroller boards. It could also be attached to most other microcontrollers via jumpers.
Thank you. I figured that was the case. I guess I need to hurry and order one. Any suggestion for which one for this simple task?
The Feather M0 Express would be a good choice: https://www.adafruit.com/product/3403
It can be programmed in either Arduino or CircuitPython. And it has a small prototyping area in case you want to add any circuitry for additional features on your animatronics.
Latinsk8er
Thanks again!!
Latinsk8er
So now I have my M0 Express and my Servo Featherwing. I have it all soldered up and connected. I have power to the wing and to the Express. I have a MG90D servo connected to servo channel 0 but I cannot get it to move. I am using MU and this is the code I copied from a tutorial, but I keep getting a error that "pca in not define". I don't know what to define it as.
1 import board
2 import busio
3
4 i2c = busio.I2C(board.SCL, board.SDA)
5
6 import adafruit_pca9685
7
8 servo_channel[0] = pca.channels[0]
9
10 pca.frequency = 50
11
12 import adafruit_motor.servo
13 servo = adafruit_motor.servo.Servo(servo_channel)
14 servo.angle = 180
My ultimate goal is to have the servo go from 0 to 180 and back every 10 seconds. I have been searching for 2 days on how to do this. I can't get the servo to move. I know I am in over-my-head, but I am trying to learn. Any help would be greatly appreciated. Please and thank you.
Not sure which tutorial that code came from. The Wing tutorial has example code using the current 'servokit' library. Make sure that you have all the right libraries installed: https://learn.adafruit.com/adafruit-8-c ... es-3012512
Servo control is explained here: https://learn.adafruit.com/adafruit-8-c ... os-3012505
And example code to sweep back and forth is here: https://learn.adafruit.com/adafruit-8-c ... de-3013006
Latinsk8er
adafruit_support_bill wrote: Thu Dec 29, 2022 1:15 pm
Thank you. I cleared out my lib and replaced the code.py. IT MOVES! I just need to look at those other examples to see how to create a loop. Thanks for the help.
Latinsk8er
[/quote]
[/quote]
I finally got it to work the way I need it to!!
Good to hear. Thanks for the follow-up.
Return to “Microcontrollers”
