Adjusting Volume on MusicPlayer Sheild VS1053
ryandewitt
Post by ryandewitt »
Listening to headphones using the inline barrel jack. The musicPlayer.setVolume(20,20) line does not seem to adjust the volume. Any tips? Whether it's O or 255 makes no diff. Thanks
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// define the pins used
#define CLK 13       // SPI Clock, shared with SD card
#define MISO 12      // Input data, from VS1053/SD card
#define MOSI 11      // Output data, to VS1053/SD card
// Connect CLK, MISO and MOSI to hardware SPI pins.
// See http://arduino.cc/en/Reference/SPI "Connections"
// These are the pins used for the breakout example
#define BREAKOUT_RESET  9      // VS1053 reset pin (output)
#define BREAKOUT_CS     10     // VS1053 chip select pin (output)
#define BREAKOUT_DCS    8      // VS1053 Data/command select pin (output)
// These are the pins used for the music maker shield
#define SHIELD_RESET  -1      // VS1053 reset pin (unused!)
#define SHIELD_CS     7      // VS1053 chip select pin (output)
#define SHIELD_DCS    6      // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 4     // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 3       // VS1053 Data request, ideally an Interrupt pin
// The relay to control the tens unit
#define SWITCH 7
// Define timing
#define SOUND_ON_TIME 5
#define SOUND_DELAY 5
#define SWITCH_ON_TIME 5
#define SWITCH_DELAY 5
int mode;
int previousRandomInt = 0;
char randNumberString = "wav";
long indexToWrite;
long randNumber = random(3);
char toPlay[11];     //  string array for file to play 00.mp3 to 49.mp3
Adafruit_VS1053_FilePlayer musicPlayer =
  // create shield-example object!
  Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
  Serial.begin(9600);
  pinMode(SWITCH, OUTPUT);
  Serial.println("VS1053 Simple Test");
  if (! musicPlayer.begin()) { // initialise the music player
     Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
     while (1);
  Serial.println(F("VS1053 found"));
musicPlayer.sineTest(200, 500);    // Make a tone to indicate VS1053 is working
   if (!SD.begin(CARDCS)) {
    Serial.println(F("SD failed, or not present"));
    while (1);  // don't do anything more
  // Set volume for left, right channels. lower numbers == louder volume!
  musicPlayer.setVolume(20,20);
  // If DREQ is on an interrupt pin (on uno, #2 or #3) we can do background
  // audio playing
  musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT);  // DREQ int
adafruit_support_mike
Re: Adjusting Volume on MusicPlayer Sheild VS1053
What are you using as a power source?
Speakers.. even headphones.. are current-hungry, and the most common reason for "changing the volume has no effect" is that the power supply is already maxed out.
