Adafruit connect not working anymore
gvandesompel
Post by gvandesompel »
hello all,
I hope somebody can help me out here with a strange issue. (project: "soil moisture measurement")
The code below is working since quite some time on an old ESP8266.(ESP12 mod) It' still functional.
I've uploaded the same code to another new ESP8266. This doesn't work: Error "Disconnected from Adafruit IO" ??
I am sure The Wifi connection is online. ( IP address etc) but on this new similar device there is no Adafruit IO connection possible?
The right Adafruit login + key is written in the config file.
Somebody? I am really lost.
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
// vochtsensor pin
#define PULS_PIN 5 //D1
#define SENSOR_PIN A0
// photocell state
int current = 0;
int last = -1;
// set up the 'analog' feed
AdafruitIO_Feed *analog = io.feed("analog2");
  // setup de vochtsensor pins
  pinMode(PULS_PIN, OUTPUT);
  digitalWrite(PULS_PIN, LOW);
  // start the serial connection
  Serial.begin(115200);
  // wait for serial monitor to open
  while(! Serial);
  // connect to io.adafruit.com
  Serial.print("Connecting to Adafruit IO");
  io.connect();
  // wait for a connection
  while(io.status() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  // we are connected
  Serial.println();
  Serial.println(io.statusText());
  // io.run(); is required for all sketches.
  // it should always be present at the top of your loop
  // function. it keeps the client connected to
  // io.adafruit.com, and processes any incoming data.
  io.run();
  //lezen van de vochtsensor
  digitalWrite(PULS_PIN, HIGH);
  int meting = analogRead(SENSOR_PIN);
  current = meting;
  // return if the value hasn't changed
  if(current == last)
    return;
  // save the current state to the analog feed
  Serial.print("sending -> ");
  Serial.println(current);
  analog->save(current);
  // store last photocell state
  last = current;
  // wait three seconds (1000 milliseconds == 1 second)
  // because there are no active subscriptions, we can use delay()
  // instead of tracking millis()
  delay(30000);
bidrohini
Re: Adafruit connect not working anymore
Post by bidrohini »
Is the second ESP really functional? Have you tested that board separately? Disconnect your sensor and try to upload a simple code to that second ESP board. This way you can make sure if the esp is good or not.
gvandesompel
Yes, this one is functional.
I even tried with 2 new ones. A simple wifiscan sketch is functional.
The only difference between the 2 new esp's and the working old one is it's another brand. ( pin layout is the same however)
It's very strange. :-(
gvandesompel
It appears the solution was an upgrade of the ESP8266 package in the Arduino Board manager!
I don't understand why. I didn't realize before this could be so sensitive for the same code on a newer ESP device.
I would appreciate it if somebody could explain the "reason why" to me...?
brubell
Learn User Page
Post by brubell »
The Arduino ESP8266 core hasn't been released for a while, see latest releases here: https://github.com/esp8266/Arduino/releases
Likely your board was running a much older version of the board support package and the latest version fixed some bug within WiFi or MQTT connectivity.
gvandesompel
brubell wrote: Tue Jan 03, 2023 2:08 pm The Arduino ESP8266 core hasn't been released for a while, see latest releases here: https://github.com/esp8266/Arduino/releases
Return to “Internet of Things: Adafruit IO and Wippersnapper”
