REST server library?
- jetforme
I was looking for something to help me in adding a REST API to my device (based on a Feather MO+ATWINC). There are some docs for the WICED device, but they seem to be out of date as that library doesn't seem to exist any more. Or at least, I can't find the AdafruitHTTPServer.
- mikeysklar
- jetforme
Re: REST server library?
Thanks, Mikey. Problem is, I can't find the library that belongs to. The repo says to use the Boards Manager to add WICED. Does that mean AdafruitHTTPServer can't be used with other boards?
- mikeysklar
I was at a race all week. My apologies for the delay.
I do see the Adafruit WICED BSP from Arduino Boards Manager when using the necessary Additional Board Manager URLs.
https://adafruit.github.io/arduino-boar ... index.json
Other non-WICED boards would not be able to use this AdafruitHTTPServer.
Was there a specific board you wanted to also run a webserver on? There is a general CircuitPython httpserver that can be used on many boards. You can also interact with AIO via REST which would maximize your hardware options.
https://docs.circuitpython.org/projects ... t/api.html
https://learn.adafruit.com/adafruit-io/rest-api
