How do I do Servo code for RFM69 Radio?
animefruit
Post by animefruit »
Can you tell me the code I need to use for servos to be registered rather than button presses for the RadioHead69_RawDemoTXRX_OLED code?
Do I use the same servo code as usual from the Sweep example sketch or to I have to use something else because it is code for the RFM69 Radio?
Here is the code for the RadioHead69_RawDemoTXRX_OLED code:
    // rf69 demo tx rx oled.pde
// -*- mode: C++ -*-
// Example sketch showing how to create a simple messageing client
// with the RH_RF69 class. RH_RF69 class does not provide for addressing or
// reliability, so you should only use RH_RF69  if you do not need the higher
// level messaging abilities.
// It is designed to work with the other example rf69_server.
// Demonstrates the use of AES encryption, setting the frequency and modem
// configuration
#include <SPI.h>
#include <RH_RF69.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
/************ OLED Setup ***************/
Adafruit_SSD1306 oled = Adafruit_SSD1306();
#if defined(ESP8266)
  #define BUTTON_A 0
  #define BUTTON_B 16
  #define BUTTON_C 2
  #define LED      0
#elif defined(ESP32)
  #define BUTTON_A 15
  #define BUTTON_B 32
  #define BUTTON_C 14
  #define LED      13
#elif defined(ARDUINO_STM32F2_FEATHER)
  #define BUTTON_A PA15
  #define BUTTON_B PC7
  #define BUTTON_C PC5
  #define LED PB5
#elif defined(TEENSYDUINO)
  #define BUTTON_A 4
  #define BUTTON_B 3
  #define BUTTON_C 8
  #define LED 13
#elif defined(ARDUINO_NRF52832_FEATHER)
  #define BUTTON_A 31
  #define BUTTON_B 30
  #define BUTTON_C 27
  #define LED 17
#else // 32u4, M0, and 328p
  #define BUTTON_A 9
  #define BUTTON_B 6
  #define BUTTON_C 5
  #define LED      13
#endif
/************ Radio Setup ***************/
// Change to 434.0 or other frequency, must match RX's freq!
//#define RF69_FREQ 915.0
#define RF69_FREQ 434.0
#if defined (__AVR_ATmega32U4__) // Feather 32u4 w/Radio
  #define RFM69_CS      8
  #define RFM69_INT     7
  #define RFM69_RST     4
#endif
#if defined(ARDUINO_SAMD_FEATHER_M0) // Feather M0 w/Radio
  #define RFM69_CS      8
  #define RFM69_INT     3
  #define RFM69_RST     4
#endif
#if defined (__AVR_ATmega328P__)  // Feather 328P w/wing
  #define RFM69_INT     3  //
  #define RFM69_CS      4  //
  #define RFM69_RST     2  // "A"
#endif
#if defined(ARDUINO_ADAFRUIT_FEATHER_ESP32S2) || defined(ARDUINO_NRF52840_FEATHER) || defined(ARDUINO_NRF52840_FEATHER_SENSE)
  #define RFM69_INT     9  // "A"
  #define RFM69_CS      10  // "B"
  #define RFM69_RST     11  // "C"
  #define LED           13
#elif defined(ESP32)    // ESP32 feather w/wing
  #define RFM69_RST     13   // same as LED
  #define RFM69_CS      33   // "B"
  #define RFM69_INT     27   // "A"
#endif
#if defined(ARDUINO_NRF52832_FEATHER)
  /* nRF52832 feather w/wing */
  #define RFM69_RST     7   // "A"
  #define RFM69_CS      11   // "B"
  #define RFM69_INT     31   // "C"
  #define LED           17
#endif
// Singleton instance of the radio driver
RH_RF69 rf69(RFM69_CS, RFM69_INT);
void setup()
  delay(500);
  Serial.begin(115200);
  //while (!Serial) { delay(1); } // wait until serial console is open, remove if not tethered to computer
  // Initialize OLED display
  oled.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3C (for the 128x32)
  oled.display();
  delay(500);
  oled.clearDisplay();
  oled.display();
  pinMode(BUTTON_A, INPUT_PULLUP);
  pinMode(BUTTON_B, INPUT_PULLUP);
  pinMode(BUTTON_C, INPUT_PULLUP);
  pinMode(LED, OUTPUT);
  pinMode(RFM69_RST, OUTPUT);
  digitalWrite(RFM69_RST, LOW);
  Serial.println("Feather RFM69 RX/TX Test!");
  // manual reset
  digitalWrite(RFM69_RST, HIGH);
  delay(10);
  delay(10);
  if (!rf69.init()) {
    Serial.println("RFM69 radio init failed");
    while (1);
  Serial.println("RFM69 radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM (for low power module)
  // No encryption
  if (!rf69.setFrequency(RF69_FREQ)) {
    Serial.println("setFrequency failed");
  // If you are using a high power RF69 eg RFM69HW, you *must* set a Tx power with the
  // ishighpowermodule flag set like this:
  rf69.setTxPower(14, true);
  // The encryption key has to be the same as the one in the server
  uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
                    0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
  rf69.setEncryptionKey(key);
  Serial.print("RFM69 radio @");  Serial.print((int)RF69_FREQ);  Serial.println(" MHz");
  // OLED text display tests
  oled.setTextSize(2);
  oled.setTextColor(WHITE);
  oled.setCursor(0,0);
  oled.println("RFM69 @ ");
  oled.print((int)RF69_FREQ);
  oled.println(" MHz");
  oled.display();
  delay(500);
void loop()
{  if (rf69.waitAvailableTimeout(100)) {
    // Should be a message for us now
    uint8_t buf[RH_RF69_MAX_MESSAGE_LEN];
    uint8_t len = sizeof(buf);
    if (! rf69.recv(buf, &len)) {
      Serial.println("Receive failed");
      return;
    digitalWrite(LED, HIGH);
    rf69.printBuffer("Received: ", buf, len);
    buf[len] = 0;
    Serial.print("Got: "); Serial.println((char*)buf);
    Serial.print("RSSI: "); Serial.println(rf69.lastRssi(), DEC);
    oled.println((char*)buf);
    oled.print("RSSI: "); oled.print(rf69.lastRssi());
    oled.display();
    digitalWrite(LED, LOW);
  if (!digitalRead(BUTTON_A) || !digitalRead(BUTTON_B) || !digitalRead(BUTTON_C))
    Serial.println("Button pressed!");
    char radiopacket[20] = "Button #";
    if (!digitalRead(BUTTON_A)) radiopacket[8] = 'A';
    if (!digitalRead(BUTTON_B)) radiopacket[8] = 'B';
    if (!digitalRead(BUTTON_C)) radiopacket[8] = 'C';
    radiopacket[9] = 0;
    Serial.print("Sending "); Serial.println(radiopacket);
    rf69.send((uint8_t *)radiopacket, strlen(radiopacket));
    rf69.waitPacketSent();
I also Simplified the RadioHead69_RawDemoTXRX_OLED
I commented any piece of code that wasn't needed for the code to work.
Here is my Simplified code:
  #define BUTTON_A 9
  #define BUTTON_B 6
  #define BUTTON_C 5
  #define LED      13
//#endif
#endif
void setup()
  delay(500);
  // manual reset
  if (!rf69.init()) {
    while (1);
  }    // failed
  delay(500);
void loop()
   if (! rf69.recv(buf , & len )) {
      return;
    buf[len] = 0;
    Serial.print("Got: "); Serial.println((char*) buf);
    radiopacket[9] = 0;
bidrohini
Re: How do I do Servo code for RFM69 Radio?
Post by bidrohini »
Not exactly what you're looking for. But You can get some ideas from the following links:
https://lowpowerlab.com/forum/projects/ ... ontrol/15/
https://www.researchgate.net/publicatio ... ransceiver
animefruit
Thanks bidrohini.
I looked at that code you sent me but still don't know how to include it in my code because that is code for controlling a servo with the radio when I just want code for sending a message to the serial monitor through the radio when the servo has moved.
I think would be best to use this code I made.
Here is the code I made:
  #include <Servo.h>
#include "Wire.h"
#include "Adafruit_LiquidCrystal.h"
#define LED 13// FOR LED
Adafruit_LiquidCrystal lcd(0);
Servo myservo1;
Servo myservo2;
//cant do A4 and A5(they are for lcd)
// Analogs 0 to 5
const int knockSensor = A0;
const int knockSensor1= A1;
const int knockSensor2= A2;
const int knockSensor3= A3;
const int knockSensor4= A6;
const int knockSensor5= A7;
const int threshold = 0;
int health = 500;
// 6 total sensor readings (from 0 to 5)
int sensorReading = 0;
int sensorReading1 =0;
int sensorReading2 =0;
int sensorReading3 =0;
int sensorReading4 =0;
int sensorReading5 =0;
int pos =0;
int deaths=1;// gonna be number of deaths
void setup()
 // pinMode(LED_BUILTIN, OUTPUT); //LED ON ARDUINO
  pinMode(LED, OUTPUT);//FOR LED
  Serial.begin(9600);
  Serial.println("Nerf Target v0.0.1, github.com/mcoms/nerf-target, 2014.");
// sg90
  lcd.begin (20 , 4);
  lcd.clear();
  Serial.begin(9600);
  myservo1.attach(9);
  myservo1.write(0);//was 0
  myservo2.attach(10);
  myservo2.write(45);//was 179
void loop()
  do
    myservo1.detach();
    myservo2.detach();
    sensorReading = analogRead(knockSensor);
    lcd.setCursor(0, 1);
    Serial.println(health);
    lcd.println(health);
    if (sensorReading > threshold) {
      Serial.println("Knock!");
      health = health - sensorReading;
      Serial.print(sensorReading);
      lcd.print(sensorReading);
      int sensorValue = analogRead(A0);
      Serial.println(sensorValue);
      delay(1);
//duplicate
sensorReading1= analogRead(knockSensor1);
 if (sensorReading1 > threshold) {
      health = health - sensorReading1;
      Serial.print(sensorReading1);
      lcd.print(sensorReading1);
      int sensorValue = analogRead(A1);
      delay(1);
//duplicate
sensorReading2= analogRead(knockSensor2);
 if (sensorReading2 > threshold) {
      health = health - sensorReading2;
      Serial.print(sensorReading2);
      lcd.print(sensorReading2);
      int sensorValue = analogRead(A2);
      delay(1);
//duplicate
sensorReading3= analogRead(knockSensor3);
 if (sensorReading3 > threshold) {
      health = health - sensorReading3;
      Serial.print(sensorReading3);
      lcd.print(sensorReading3);
      int sensorValue = analogRead(A3);
      delay(1);
//duplicate
sensorReading4= analogRead(knockSensor4);
 if (sensorReading4 > threshold) {
      health = health - sensorReading4;
      Serial.print(sensorReading4);
      lcd.print(sensorReading4);
      int sensorValue = analogRead(A6);
      delay(1);
//duplicate
sensorReading5= analogRead(knockSensor5);
 if (sensorReading5 > threshold) {
      health = health - sensorReading5;
      Serial.print(sensorReading5);
      lcd.print(sensorReading5);
      int sensorValue = analogRead(A7);
      delay(1);
  } while (health > 1);
  digitalWrite(LED_BUILTIN, HIGH);
  delay(2000);//was 2000             // FOR LED IN ARDUINO
  digitalWrite(LED_BUILTIN, LOW);
  delay(1000);
delay(2000);                 //FOR LED
delay(1000);
  myservo1.attach(9);
  delay(15);
 for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
    // in steps of 1 degree
    myservo1.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15 ms for the servo to reach the position
  for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
 delay(1000);
 lcd.setCursor(0, 2);
      Serial.println(deaths); //showind number of deaths on the lcd
      lcd.println(deaths);
deaths= deaths + 1;// adding deaths
  health = 500;
This code I made moves a servo after the sensors have been pressed to much.
But I want the it to send a message to the serial monitor through the radio when the servo has moved.
Can you tell me what code is used to send a message to the serial monitor through the radio when the servo has moved?
Return to “Arduino”
