I recently purchased a Adafruit RGB Matrix Shield and Metro 320 Arduino board so I can control a 32x64 P5 panel. However I am not getting good results with any of the example code.
Expected Results:
Text, shapes, etc per the library example code
Actual Results:
Generally nothing. Occasionally, noise appears on the screen, usually in terms of colored horizontal lines, but sometimes scattered dots.
How I tried to test:
I assumed I had a bad solder connection, so I triple checked these and reflowed them. No luck. Then I used a multimeter to verify the pins on the 8-pin connector had continuity with the pins on the bottom of the shield, ruling out any soldering problems.
I did note that most of the pages talk about using the Metro 328 but on the library page it's not listed as a supported board. Did I screw up and buy the wrong board? As I said, all the wiring pages, etc talk about it so that's why I purchased it.
RGB Matrix Library and RGB Matrix Shield
- mikeysklar
Re: RGB Matrix Library and RGB Matrix Shield
You will need to use a microcontroller with more memory.
The Adafruit Metro M4 would be a great choice.
https://www.adafruit.com/product/3382
https://www.adafruit.com/product/2601Note that this shield is just a wiring adapter, if you have a Metro 328 you can only use 16x32 or possibly 32x32 matrices before you run out of RAM. For big panels, use a Metro M0 or M4 - those will work best thanks to their enormous RAM.
- Rehcsifmit
Thanks for the reply. I saw this quote on that same page:
Disappointed, that text is misleading.
And ordered the 328 since that seemed to be "recommended".If you've got an Arduino-compatible board, with an ATmega328p chip (like our Metro 328) or SAMD21 (like the Metro M0) or even SAMD51 (like our Metro M4) thi
- Rehcsifmit
Will the M4, or any Arduino board, support 2 64x32 boards in a horizontal chain?
Thanks again for your help.
- mikeysklar
I don't see the misleading part about the text. It is clearly stearing you away from a atmel 328p based boards due to the large memory requirement.
The M4 and modern boards nRF52, ESP32-S2, RP2040 have the memory to support chained 64x32. Just stay away from the older atmel mega based boards which do not have enough memory.
- Rehcsifmit
"Misleading" is probably too harsh. The 328 was the first board mentioned above, and I clearly skimmed too much to see the disclaimer down below.mikeysklar wrote: ↑Mon Jan 09, 2023 2:29 pm I don't see the misleading part about the text. It is clearly stearing you away from a atmel 328p based boards due to the large memory requirement.
I saw the text in the library with the disclaimer about the "Uno" boards, but I don't know enough about Adafruit's variations on Arduino to have realized that that should have also warned me away from the 328.
- mikeysklar
You make a good point that there are a lot of processors and boards and it is difficult to determine which ones are modern with more features.
If it were me working on a project to drive two RGB panels I'd go with a board designed to do exactly that.
The Matrix Portal is M4 based + WiFi and has a HUB-75 connector to go right on to the back of the RGB panels. You can chain panels easily up to 4x4.
; matrix portal M4
https://www.adafruit.com/product/4745
; advanced chaining panels
https://learn.adafruit.com/rgb-led-matr ... ple-panels
; matrix portal M4
