Flora Sewable Neopixels and BBC Microbit
Wearable electronics: boards, conductive materials, and projects from Adafruit!
StephCote
Post by StephCote »
I'm a very beginner with coding, so I use the BBC Microbit system and block's coding. I'm wondering if I can use the little Flora sewable noepixels with the Microbit as the board (not the Flora board). I bought Flora Neopixels - Flora RGB Smart NeoPixel version 2 - Sheet of 20 (Product ID: 1559) and I try to connect them to the Microbit, and only the first little Flora is doing what I'd code. The others are doing just flashing red, that's it. Is it normal?
Thank you for helping me.
dastels
Re: Flora Sewable Neopixels and BBC Microbit
Post by dastels »
Neopixels only do what the code tells them to do. So they aren't flashing, they are being flashed by the code. Can you post your code. You can "block's" which I am assuming means MakeCode? If so you can post a screenshot of it.
Return to “Wearables”
