Is this code is correct?
KISHEN21
Post by KISHEN21 »
void loop()
   MQTT_connect();
Adafruit_MQTT_Subscribe * subscription;
while ((subscription = mqtt.readSubscription(5000)))
   if (subscription == &Smartlock)
      //Print the new value to the serial monitor
      Serial.println((char*) Smartlock.lastread);
   else if (!strcmp((char*) Smartlock.lastread, "Close"))
        digitalWrite(14, LOW);
        Serial.println("Door Unlocked");
        digitalWrite(12, HIGH);
        delay(2000);
        digitalWrite(12, LOW);
   else if (!strcmp((char*) Smartlock.lastread, "Open"))
        digitalWrite(14, HIGH);
        Serial.println("Door Closed");
        delay(2000);
dastels
Re: Is this code is correct?
Post by dastels »
It depends on what you mean by "correct".
Does it compile? Link? Upload? Do what you intend?
KISHEN21
Post by KISHEN21 »
Hi,I can able to upload the code.But the code is not working when I connect to the circuit.Im doing IOT solenoid lock.I cant able to control the solenoid lock.
sj_remington
Post by sj_remington »
What circuit?
Do you have a suitable driver and power supply for the solenoid?
KISHEN21
Post by KISHEN21 »
Im using 12v battery for supply
Screenshot 2023-01-15 135741.png (69.1 KiB) Viewed 137 times
dastels
Post by dastels »
I can't make out the pin labels on the boards. Do you have a higher resolution image?
How are you powering the MCU board? What about current specs of the 12v supply and solenoid lock?
Return to “Internet of Things: Adafruit IO and Wippersnapper”
