I can't get my qt py esp32 s2 to respond!
ovin08
Post by ovin08 »
I haven't messed with this board in a while but I can't get it to respond at all in Arduino IDE or Thonny(I can't remember which I used last for it but I know I put a simple blink app on there since the neo is flashing green)
After the board constantly gets a Port Busy error when uploading a sketch I try Thonny which just gives me a COMx: PermissionError, Access is denied.
Then I think I might need to reload a bootloader for Arduino IDE so I use the web esptool https://adafruit.github.io/Adafruit_WebSerial_ESPTool/, but the board in boot mode and try to connect and get 'Failed to open serial port'.
Then I try to manually use the esptool.exe that arduino IDE uses but I get 'COM9 failed to connect: Could not open COM9, the port doesn't exist'
I'm at a loss for what to try next since the board just simply won't respond to anything I try.
Also, nothing is attached to any pins since I've seen that stop sketches from uploading before.
adafruit_support_carter
Re: I can't get my qt py esp32 s2 to respond!
Double check the COM port being selected.
See what COM ports are listed in Device Manager *before* connecting the QT Py. Then connect the QT Py and enter ROM bootloader mode:
https://learn.adafruit.com/adafruit-qt- ... de-3106832
and see what COM port shows up. Use that one.
Since you've already tried esptool, try testing the connection again using that with a chip_id check:
https://learn.adafruit.com/adafruit-qt- ... ct-3108538
to verify the basic connection is working.
ovin08
Post by ovin08 »
No COM ports exist before plugging in the py.
I used a device cleanup tool and removed a lot of defined com ports so I got a new one assigned to the py in regular and boot mode but that didn't help.
Trying to get the chip_id in regular and boot mode gets the same result:
esptool.py v4.2.1
Serial port COM4
A fatal error occurred: Could not open COM4, the port doesn't exist
The board must be in ROM bootloader mode (see link above) to query the chip id.
Does Device Manager show a COM4 entry at the same time you get that error message?
ovin08
Post by ovin08 »
It turns out it was just an Arduino IDE and pc issue. A java process must have been holding things up, even in thonny. After a shutdown of all related things the board is showing back up again. False alarm :/
Return to “Microcontrollers”
