I have an Adafruit Clue and plugged it into my Robot:bit. It allows me to power it with the Robot:bit battery.
Is there any reason I can't use these devices together? I'm programming in Python.
I feel that I should be able to address the ports and pins on the Robot:bit, no?
Adafruit Clue and Robot:bit
- bidrohini
Re: Adafruit Clue and Robot:bit
As far as I understand, there should be no problem with using Robot:bit with Adafruit Clue. Because Adafruit Clue can be powered by any 3-6V battery source.
- adafruit_support_mike
That should be fine. The Robot:bit is designed to connect to a Micro:bit easily, but doesn't require one. As long as you connect it to a 3.3V device the signals will be fine.
