QT PY ESP32 Pico not recognized by Whippersnapper
robertr729
Post by robertr729 »
I have flashed the firmware for my QT PY ESP32 Pico successfully and the IO Whippersnapper interface does not recognize my board. I've tried other cables to no avail. I have a yellow/green light on the board after the download. I'm running on an MAC. I've downloaded the drivers too.
bidrohini
Re: QT PY ESP32 Pico not recognized by Whippersnapper
Post by bidrohini »
Try this troubleshooting guideline: https://learn.adafruit.com/adafruit-qt- ... pper-setup
Is your QT PY working otherwise? Can you upload codes to it using the Arduino IDE?
brubell
Learn User Page
Post by brubell »
robertr729 wrote: Sun Jan 22, 2023 6:25 pm I have flashed the firmware for my QT PY ESP32 Pico successfully and the IO Whippersnapper interface does not recognize my board. I've tried other cables to no avail. I have a yellow/green light on the board after the download. I'm running on an MAC. I've downloaded the drivers too.
First, double-check the adafruit io username and key in the secrets.json file on your WIPPER drive. Then, double-check the wifi ssid and password in the secrets.json file on your WIPPER drive.
If the values within the secrets.json file look correct, let me know and I can help you with next steps.
Return to “Internet of Things: Adafruit IO and Wippersnapper”
