I also tried using a voltage regulator at a lower voltage (2v) but that's not helping.
It is getting a consistent 3.3v.
The circuit is simply:
- pin 1 (3.3v) to Vin
- pin 14 ground to gnd
- gpio 2 (sda) to sda
- gpio3 (scl) to scl
I wondered if it might have something to do with the communication to Sonic pi. But if I unplug it for about 5 minutes it starts working again which makes me think maybe not. Just restarting doesn't work, it has to be unplugged for a bit. I also wondered if it might be overheating but I put a fan right on it and that didn't seem to help either.
Could it be some kind of stack overflow-ish kind of thing? Is there a step I need to do to empty a buffer or something?
Could someone please help me? It's driving me nuts!
Thanks (code follows),
Larry
########################################## THE CODE ######################################
import qwiic
import time
from pythonosc import osc_message_builder
from pythonosc import udp_client
#object for sonic pi
sender = udp_client.SimpleUDPClient('127.0.0.1', 4560)
notes = {4.5:"C3",
4.0:"D3",
3.5:"E3",
3.0:"F3",
2.5:"G3",
2.0:"A3",
1.5:"B3",
1.0:"C4",
0.5:"D4",
0:"E4"}
puzzle_notes = [0.5, 0, 1.0, 4.5, 2.5, 99]
win =0
last_dist = 6
current_target_tone = 0
time_target_tone_held = 0
num_hits = 0
time_since_last_change = 0
time_since_last_hit = 0
# ------------------- LASER INPUT --------------------------------
ToF = qwiic.QwiicVL53L1X()
def distance():
ToF.start_ranging() # Write configuration bytes to initiate measurement
time.sleep(.005)
distance = ToF.get_distance() # Get the result of the measurement from the sensor
time.sleep(.005) #originally .00
ToF.stop_ranging()
distanceInches = distance / 25.4
distanceFeet = distanceInches / 12.0
print("Distance(mm): %s Distance(ft): %s" % (distance, distanceFeet))
return distanceFeet
if (ToF.sensor_init() == None): # Begin returns 0 on a good init
print("Sensor online!\n")
####################### MAIN LOOP #########################
try:
while win == 0:
dist = round(distance()*2)/2
print ("Measured Distance = %.1f cm" % dist)
# count how long each note is held
time_since_last_change = time_since_last_change + 1
print("time since change: {}".format(time_since_last_change))
time_since_last_hit = time_since_last_hit + 1
if dist < 4.6: #Only play note when players are close enough to play
#check to see if dist has changed
if dist != last_dist:
print("note changed")
print("distance: {} last distance: {}".format(dist, last_dist))
last_dist = dist
# if it's over 2 seconds - check if it's the current target tone
if time_since_last_change > 20 and dist == puzzle_notes[current_target_tone]:
# print("####################### CORRECT NOTE ###########")
# then increase the num_hits and increment current_target_tone
current_target_tone = current_target_tone + 1
num_hits = num_hits + 1
print("NUMBER OF HITS {})".format(num_hits))
if time_since_last_hit > 150:
# if it's too long between correct notes reset current_target_tone to 0
num_hits = 0
print("TOO LONG BETWEEN HITS")
# if it's > 5 go to win sequence
if num_hits >= 5:
print ("******** YOU WIN!!! *****")
win = 1
# send notes to sonic pi
sender.send_message('/trigger/foo', [notes[dist], notes[puzzle_notes[current_target_tone]]])
# print ("sending {} and {}".format(notes[dist], notes[puzzle_notes[current_target_tone]]))
time.sleep(.05)
except Exception as e:
print(e)
