Having Trouble Controlling Stepper Motor with TB67S128FTG Driver
JJMoney
Post by JJMoney »
I am having trouble driving this stepper motor with my TB67S128FTG driver. I’ve ensured there is voltage at V_in (~12.2V) and VCC (~5V). Are there any other pins I should expect to have a voltage
that could help diagnose the issue? The code I’ve written is below (all of the print statements are executing):
from time import sleep
import RPi.GPIO as GPIO
DIR = 24
STEP = 25
CW = 1
CCW = 0
SPR = 200 # steps per revolution: 360 / 1.8
def main():
    print("DIR = " + str(DIR))
    print("STEP = " + str(STEP))
    GPIO.setmode(GPIO.BCM)
    GPIO.setup(DIR, GPIO.OUT)
    GPIO.setup(STEP, GPIO.OUT)
    GPIO.output(DIR, CW)
    step_count = SPR # 1 full rotation
    delay = 0.0208
    for i in range(step_count):
        GPIO.output(STEP, GPIO.HIGH)
        sleep(delay)
        GPIO.output(STEP, GPIO.LOW)
        sleep(delay)
    print("done")
    GPIO.cleanup()
if _name_ == "__main__":
    main()
Is there something I’m overlooking in this code?
I have attached a diagram of how I have wired my Raspberry Pi to my driver along with some photos of my soldering connections.
Interestingly, I disconnected the Raspberry Pi from power and the motor sounded like it was moving until I powered up the RPi again. Did I possibly blow the motor?
Re: Having Trouble Controlling Stepper Motor with TB67S128FTG Driver
I don't see anything in your code to control the Enable or /Standby pins. Those need to be in the correct state for there to be any output to the motor.
Other than that, we have no firsthand experience with that motor or controller. The folks at Pololu are pretty helpful and should be able to help you out.
