MLX90640 not found when running MLX90640_simpletest
alixdujardin
Post by alixdujardin »
Hello, I just bought an Adafruit pybadge and an IR camera. I am following these instructions https://learn.adafruit.com/mlx90640-the ... -libraries
I bought the board on amazon because it wasn't available on Adafruit, so we soldered the 12C connector ourselves because it wasn't there originally (see the file attached).
I have an error on the screen that says, "MLX90640 not found!" even though I can verify and upload my code on the computer.
What can I do to fix it?
Thank you for your help!
adafruit_support_carter
Re: MLX90640 not found when running MLX90640_simpletest
Looks like the connector is reversed. Here are the pins:
FYI - The PyBadge variant you bought is the LC version:
https://www.adafruit.com/product/3939
which is why the connectors were not installed.
The base version of the PyBadge is this one:
https://www.adafruit.com/product/4200
alixdujardin
Thank you, now the on from the camera turns green, but my screen stays black when I try to run it. What should I do?
Try running an I2C scan to see if the MLX shows up:
https://learn.adafruit.com/scanning-i2c ... s/overview
Hopefully it, or the PyBadge, wasn't damaged by the reversed connection.
alixdujardin
I ran it, the screen turned back on the "home page" and black again, but when I ran the example code arcada_bypage_test, I have something on my screen
Which I2C scanner program did you run? What output did it generate?
alixdujardin
I ran this one
// i2c_scanner
// Modified from https://playground.arduino.cc/Main/I2cScanner/
#include <Wire.h>
// Set I2C bus to use: Wire, Wire1, etc.
#define WIRE Wire
  WIRE.begin();
  Serial.begin(9600);
  while (!Serial)
     delay(10);
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    WIRE.beginTransmission(address);
    error = WIRE.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknown error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
  else
    Serial.println("done\n");
  delay(5000);           // wait 5 seconds for next scan
And I had this output
Sketch uses 12836 bytes (2%) of program storage space. Maximum is 507904 bytes.
Device       : ATSAMD51x19
Version      : v1.1 [Arduino:XYZ] Jun 23 2019 17:44:37
Address      : 0x0
Pages        : 1024
Page Size    : 512 bytes
Total Size   : 512KB
Planes       : 1
Lock Regions : 32
Locked       : none
Security     : false
BOD          : false
BOR          : true
Write 13092 bytes to flash (26 pages)
[                              ] 0% (0/26 pages)
[=========                     ] 30% (8/26 pages)
[==================            ] 61% (16/26 pages)
[===========================   ] 92% (24/26 pages)
[==============================] 100% (26/26 pages)
Done in 0.209 seconds
Verify 13092 bytes of flash
[=                             ] 3% (1/26 pages)
[==                            ] 7% (2/26 pages)
[===                           ] 11% (3/26 pages)
[====                          ] 15% (4/26 pages)
[=====                         ] 19% (5/26 pages)
[======                        ] 23% (6/26 pages)
[========                      ] 26% (7/26 pages)
[==========                    ] 34% (9/26 pages)
[===========                   ] 38% (10/26 pages)
[============                  ] 42% (11/26 pages)
[=============                 ] 46% (12/26 pages)
[===============               ] 50% (13/26 pages)
[================              ] 53% (14/26 pages)
[=================             ] 57% (15/26 pages)
[===================           ] 65% (17/26 pages)
[====================          ] 69% (18/26 pages)
[=====================         ] 73% (19/26 pages)
[=======================       ] 76% (20/26 pages)
[========================      ] 80% (21/26 pages)
[=========================     ] 84% (22/26 pages)
[==========================    ] 88% (23/26 pages)
[============================  ] 96% (25/26 pages)
Verify successful
Done in 0.114 seconds
You'll need to open the Arduino Serial Monitor to see the actual scanner output. What you've pasted above is just the compile and upload messages.
The Serial Monitor should show something similar to what is shown in the guide:
https://learn.adafruit.com/scanning-i2c ... or-3102783
alixdujardin
Thanks, I have that, but I don't get it because there is a green light on the camera to say that it's connected to the board... What should I do?
Screenshot 2023-01-25 113330.jpg (6.15 KiB) Viewed 25268 times
The green LED is only an indication of power.
Is the PyBadge your only board? At this point it may be that the MLX90640 was damaged by the initial reversed connections which put power on the I2C pins.
alixdujardin
Thank you for your help, so, to be 100% sure: SCL is yellow, SDA=blue, VCC=red and GND=black?
That is the intended function for those color wires. However, the connector is keyed, so must be put on correctly. Otherwise the wrong pins will be connected to those wires.
The photo I added with the labels is for the pinout of the PyBadge itself. The connector must be placed so that when the cable is plugged in, the wire colors match to those pins.
alixdujardin
Hey, I am still struggling. I bought a new camera and connected it as you said on the new camera (see pictures), but I still have the camera not found.
alixdujardin
I forget to add, I had this output
Screenshot 2023-01-30 132126.jpg (9.89 KiB) Viewed 25260 times
The library is for use with the Adafruit MLX90640 breakout:
https://www.adafruit.com/product/4407
You'll need to contact Waveshare to see if their board will work with the library.
